Project: NAS Box
Discussion in 'Project Logs' started by Guest-16, 29 Apr 2006.
  1. malfunction
    malfunction What's a Dremel?
    5 Jun 2002
    Well if you want the other one it comes with some nice wrapping now:
    http://forums.bit-tech.net/showthread.php?t=112115
  2. Krikkit
    21 Jan 2003
    Looking good Rich, 'leccy tape and a bit of hope always does nicely for mods. :D
  3. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Overheating is it? Make the entire top into a heatsink or something :p
  4. Jipa
    5 Feb 2004
    Uuuh that's so.... so SLEEK! /me wants one..
    übersolution against overheating would be heatsink-sideplates (as seen in Be quiet), but I'm pretty sure you won't do that.
  5. Guest-16
    Guest-16 Guest
    I was considering epoxying some alu blocks to the case top which then sit on top of the disk drives but it's the fact that the air inside just accumilates heat that's the problem. There's no convection even, so it needs just a single input fan and maybe a hole and some mesh underneath (out of sight) to keep a flow of fresh air.
    The other problem is that 1" thick alu blocks the size of harddisks arent exactly easy to come by, cheaply. Whereas a fan is.
    The whole thing DOES act as a heatsink. It feels hot to touch when on (apart from being electrocuted at the same time) but a single fan hole will be far more discrete and some heatsinks would need to be massive which would make it look bad.
  6. malfunction
    5 Jun 2002
    You keep reminding me of an episode of the simpsons where they go along for family therapy and end up shocking each other.
    Are you sure the PSU is OK? I had a shuttle PSU that kept shocking me after a day of power cuts and 'brown outs'. Got rid of it before it got rid of me! (Though it was nothing like the time when I tried to repair a shower without turning the juice off... That did a bit more than 'tickle')
  7. Guest-16
    Guest-16 Guest
    Oh I stuck my hand in a live 350W PSU the other day (stupidly) to check the fan was working. That tickled me all the way to scream. Im sure the PSU is probably to blame cause of my self made connector, but if this works and I can isolate it from everything then I dont really care. I'll take a multimeter too it and check.
  8. bender386
    bender386 What's a Dremel?
    5 Jan 2006
    the fans in a psu are just as bad. nealy took the top of my finger off with one. bloody hurt was a nice big flap of skin at the top of my finger nealy cut off.
  9. gbeeby
    gbeeby What's a Dremel?
    6 Dec 2005
    dill some holes in the bottom and put a row of small fans on the back
  10. Guest-16
    Guest-16 Guest
    On the outside would detract from the clean look and small fans = uber noise. There's no space inside along the edges either.
  11. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Why not cut away from underneath the HDDs (Inside of where they are mounted) and mount some mesh there. Should let them breathe better too. :)
  12. Starman97
    Starman97 What's a Dremel?
    17 Sep 2003
    What I've seen done:
    Get a big heatsink(s) with vertical fins that runs the whole length of the back panel. Bolt an internal heatsink with horizontal fins to match it on the inside. Use HS grease on both sides to eliminate the air gap. Then use an internal fan(s) running at low speed to circulate the air inside the case, put a baffle inside to setup a 'racetrack' for the air with the forced air blowing on the heatsink , narrow side of the track. That way you dont suck dust into the box, and most of the sound stays in the box. The flat metal acts a little as a heat spreader, but must of the heat comes off the deep (2inch) fins on the back.
    You might also want to bolt some fins onto the side of your drives to help cool them.
  13. Guest-16
    Guest-16 Guest
    Ive gone for the vacuum cleaner: an 80mm under the harddisks which are being suspended an inch above the bottom, and a normal 120mm which I am cutting and supressing INTO the bottom of the case so the fanblades will be visible from underneath. I lost my frikkin drill arbator (sp?) bit for my 120mm holesaw so I was pretty pissed at the weekend as it's an expensive part and I also recon I'll just go buy an 80mm one cause they are generally very useful.
    Doesnt look like much but you can see where the 80mm drawing is and 120mm placement. The mobo is being suspended upside down almost 1.5" above the bottom and the case top has insulation I had spare to stop it shorting to it too. You can see the little legs I've made in it.
    Today I'm resoldering the ATX cable to lengthen it, and in a few weekends I'll be cutting the holes/fitting the fans. Still not found any feet I like for it.
  14. customh
    customh conflagration.
    22 Oct 2005
    What was the point of the pushbutton with the whole 8 conductor plug thing?
  15. dingledorph
    dingledorph What's a Dremel?
    4 May 2006
    I love this setup. So clean and yet so sweet.
    OT:
    Would it be possible to run a Torrent Client on FreeNAS?
  16. Guest-16
    Guest-16 Guest
    The push button is the ON switch, the 8 connector is the replacement for the ethernet plug.
    I've not tried running a torrent client, it's probably possible though.
    Update today!
    Couldnt buy a 76mm holesaw so had to buy an 83mm for an 80mm fan :( it's a little big but it worked. Nearly finished, but I ran out of cable soldering the ATX connector extensions.
    Basically I hacked the fan up to fit. The blade pertrude under the bottom of the case but it shouldnt be a problem. The mobo is a ******* to screw in upside down, and I had to use another rounded cable in replacement of the flat one cause it just didnt fit.
    It's all a little nip-tuck but it fits perfectly in the end and should provide enough airflow in.
    I want to polish the visible sides, but Ive no idea how :(
  17. Ryszvaldo
    Ryszvaldo Banned
    3 Jan 2005
    Only thing is Elbow grease Bindi - get a polishing wheel on a dremel or a drill and some polishing compound and this should bring it up a treat!
  18. Guest-16
    Guest-16 Guest
    Polishing wheels are about: (-----) that big. Alu cover is the length of my arm.
  19. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    buy a proper polishing disk, like a rotary duster, and about 12cm across, then attach it to whatever rotarty tool you like (i recmend a pillar drill, and move the item to be polished, rather than the other way round)
  20. Guest-16
    Guest-16 Guest
    That's basically it for now. Im just testing to check it wont go nuclear again, and it's not quiet anymore :(:( and I have to work out a way to really get the top on properly but that's going to require some thought.
    I think Im still getting electrocuted though :( I cant really tell. When I put my hand on it it's ok, but when I take it off I get a tingling.
