Case Mod - In Progress project natal
Discussion in 'Project Logs' started by trinity1000, 22 Nov 2010.
  1. trinity1000
    trinity1000 What's a Dremel?
    11 Sep 2010
    this is a small project (doesnt seem like ) ,which i hope to be over in 2 weeks or so. after countless of hours of design i got the right mod to this case ( i dnt know the name of it ) ..its finally down to the final hard work . so less talk more work ...:dremel:
    front has led fan controler and system status diplay..
    4 X80 mm outlet fans
    side window
    the sketch up design
    soory in advance if the render aint good ..that is all i know :)
  2. bulldogjeff
    2 Mar 2010
    Nice design, but whats with the mad angles for the pics..lol
  3. Teelzebub
    27 Nov 2009
    Doesn't look much like the Sketch Up design though. But yeah those angles :eeek:
  4. trinity1000
    11 Sep 2010
    ok ..here are more pic of the case and worklog of today
    back panel
    side
    front
    top
    so i started laying down low adhesive tape to mark drawings area
    i had to change some of the original design because i didnt for see the panel remove handle hole thingy ..not much has change tho
    started with making insertion holes for the jigsaw..small areas i was force to switch to demel which i dnt like because the cutting disk are very hard to find.infact the one im using now its now meant for this model /maker ,i had to modify it abit. :( .
    damn it started raining :( ..i have to continue tomorrow
    now this is wat i cal quicki
  5. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
    Please rotate pictures....
  6. Paradox42
    Paradox42 What's a Dremel?
    15 Oct 2010
    Ooooh, a lot of potential... subbed
  7. trinity1000
    11 Sep 2010
    continuing with the other side panel
  8. trinity1000
    11 Sep 2010
    now its holiday season i gat free time to get this project back to track
    soory there is a big gup here
    but i finished the side window too and awaiting filiing
    slight problem..one of the left top corner can close because of the 2.5mm wide fan ..
    but i have to continue with the modding
    dismantling the rest of the case ...
    refusing to unscrew
    two down 2 more to go
    apply brutal force
    later
    i wanted red led fans but the electronic didnt have more remaining
    so i bought multifans then to mod them later
    3 down 4 more to go
