Modding Project: National Security
Discussion in 'Modding' started by best49erfan, 11 Oct 2003.
  1. best49erfan
    best49erfan What's a Dremel?
    27 Dec 2002
    This is my very first project log on mods. I have modded here and there on PC's but, this one is gonna be major. Will it be Zap Wizard major? :sigh: no. I do not have all the parts, but they are slowly coming in. Here is the key part of it, the PLC program that will be loaded into an Allen-Bradly 1760-L12AWA Pico Controller. Some call this a smart relay, but really it is a low end small application PLC.
    Now, I present the start of National Security!
    10/14/03
    Completed minor Mod to case and I took some pics.
    Lower front of the case with the old bolts
    Both front pieces with the new bolts
    Detail of the new bolts
    Front of the case
    Front with the top open
    Front with whole front open
    The Side panel
    Rear Panel
    Case top
    Case top with I/O panel open
    The PLC
    PLC with cover off
    close up with cover off
    All the PLC parts
    The front panel of the PLC
  2. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    ... me confused.. :sigh:
  3. sickskater6911
    sickskater6911 What's a Dremel?
    9 Oct 2003
  4. Twernmilt
    Twernmilt What's a Dremel?
    23 Sep 2003
    Perhaps a little more insight into what we can expect?
  5. RTT
    RTT #parp
    12 Mar 2001
    best49erfan,
    We'll move your thread into project logs once you post some pics of the project developing :)
  6. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    why do you want to use PLC? Those are used on high power/voltage circuits, and have NOTHING to do in a computer due to the strong electromagnetic fiels...
    or do i get this completely wrong?
    I have worked a bit with PCL (and the systems around it.. relays, switches and all that stuff) and i think you'd be better off with some electronic circuits made for smaller electronics... not huge chunky relays...
    but again: do i get all this wrong?
  7. best49erfan
    27 Dec 2002
    PLCs are digital electronics. You can do the same thing with your huge chunky relays as you can with a plc.
  8. Smilodon
    25 Mar 2003
    I know, but using a PLC seem a bit overkill...
  9. best49erfan
    27 Dec 2002
    overkill? Funny hearing that at a modders' site.
  10. Smilodon
    25 Mar 2003
    LOL! So true, so wery true! :hehe:
  11. DRxAndy
    DRxAndy What's a Dremel?
    6 Mar 2003
    i'll be keeping my eye on this project :)
    from what best has told me about it via aim, it sounds really cool
    c'mon best, tell the folks here what you told me about all the nifty functions that your using the plc for, and why it's named national security :thumb:
  12. best49erfan
    27 Dec 2002
    Well doc,
    when i get some pics up and some more parts, they will see the greatness this project can become.............
    DrxAndy: Best49erfan Stalker across the WWW with Bit-tech and XUG!
  13. DRxAndy
    6 Mar 2003
    thats right eh
    time for an update best
    c'mon
  14. best49erfan
    27 Dec 2002
    i did a slight case mod today. pics are still in the digi cam....
  15. X-W4rrioR
    X-W4rrioR What's a Dremel?
    14 Oct 2003
    upload them ! :) i wann see
  16. djengiz
    djengiz Pointless.
    16 Aug 2002
    Need pix! :D
  17. best49erfan
    27 Dec 2002
  18. DRxAndy
    6 Mar 2003
    but you dont have any pics here yet
    c'mon man take the effort into putting them in vb code ;)
  19. bsodmike
    bsodmike Banned
    11 Oct 2002
    Quite interesting. Actually, all you need is some robotics major to decide to case mod and we will all be left in his wake. Can't wait to see any progress you make!
    :rock:
  20. best49erfan
    27 Dec 2002
    Sorry doc, I am just not as "cool" as you are by having your worklog in 9 places!
