Scratch Build – In Progress Project Nightdiver [COMPLETED]
Discussion in 'Project Logs' started by stressedmana, 14 Feb 2016.
  1. stressedmana
    stressedmana What's a Dremel?
    4 Feb 2015
    Hi everyone,
    this is my first time here and I want to show you my latest project. I also want to take part in the mod of the month competition so I hope I haven't made any mistake creating the post!
    I've started creating the skeleton of the case, using a premade motherboard base and a PCI bracket.
    From a sheet af aluminum I've made the other panel and the support for the PSU.
    Then, I used some iron to create the support fot the two panels.
    After that, made all the necessary holes and sanded for painting.
    Hope you like it so far!
  2. stressedmana
    4 Feb 2015
    Hi again,
    for the painting, I decided to use a simple black/blue code, in order to follow the colors of the components.
    Using some plexiglass to make backplates for the GPUs and a front panel to protect the components.
    Put on the mobo and all the other things.
    Bended all the tubings...
    ... and gone through the necessary leak test.
    In the next post, the final result.
  3. stressedmana
    4 Feb 2015
    And here we are, the final result!
    Hope you like it as I enjoyed making it.
    Have a good modding time you all!
    See you soon!
  4. storm-83
    storm-83 Minimodder
    7 Nov 2014
    Nice and clean!
    Good job
