Case Mod - In Progress Project: NLM. FINISHED 11.08.07
Discussion in 'Project Logs' started by jegerjon, 6 Feb 2007.
  1. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    Update 25 – Feets and psu! @ Thursday the 24th May 2007.
    Intro.
    Finally I have a new update ready!.
    Accidentally I deleted all the pics :(, So no work in process, only final shots – or actually i have a little more work to do on the feets :)
    I do really like the feets! But damn NLM seems “squared” without the outside tubing.
    The funny part
    Here’s the atx connector :)
    4-pin connector for the cpu.
    And at last, this is how the molex connectors does look.
    The orange cablesleeving goes very well with the black!
    But lets take a look at the case:
  2. jegerjon
    10 Jan 2007
    And with som light:
    The last picture, shows how all the plexi edges will look when I add leds on the rest of the case.
    What do you think? Comments are welcome!
  3. ComputerKing
    8 Sep 2006
    OMG ... Well Done :clap:
  4. derbaum
    derbaum What's a Dremel?
    11 Apr 2004
    wich colour have the leds in the foot ? on the pix it looks kinda yellowish. already thought of adding maybe a red or a orange led ? the orange of the unlighted plex looks much cooler then the lighted one.
  5. Bas van der Werff
    Bas van der Werff What's a Dremel?
    18 Feb 2007
    very nice and original feet you got there :thumb:
  6. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    I think the plexi edges need more sanding but overall it looks great.
  7. jegerjon
    10 Jan 2007
    ComputerKing @ thank you :)
    derbaum @ You're right! It's white leds, but there's only 1mm plexi on each side of the lead. Because of that It does seems a little yellow (irl it's NOT that visible, my camera like sucking the light because of the slow closer)
    Bas_van_der_werff @ thank you, if it wasn't because of the screws that's placed just beside the feets, I would properly have done them a little longer, so they'll go the edge of the case. Right know I'm thinking, trying to figure out a way doing it.
    Koradhil @ Thank you, I know about the edges, I don't think it's that visible, but you're right. Only problem doing that is that the plexi become smaller than the alu, and then it'll look weird, hope you understand.
  8. Bas van der Werff
    18 Feb 2007
    If you made the longer feet would they completely hide the screws? if that's the case you just have to drill a hole in the top of the (longer) feet so the screw diseapears into the feet, hope i made myself clear? if i didn't PM me and ill send you a small sketch of what i mean:)
  9. widmod
    widmod Minimodder
    9 Oct 2006
    nice casefeet cool continuing of the case theme :D
  10. jegerjon
    10 Jan 2007
    widmod @ thank you dude :)
    Bas_van_der_werff @ I get it, I've thought about that my self, but the only problem would be that I then had to screw the bottom on, before mounting the feets and leds, It won't be easy, but defiantly a try worth, I'll might try that later :) Thank you for the input!
  11. jegerjon
    10 Jan 2007
    Hey guys! I’ve got a little Q for you. :p
    or
    What would look best, with or with out the mesh? I don’t wan’t to drill holes for the mesh if you don’t like it. So let me hear what you think :)
    I’ll bring you an update tomorrow or Thursday, and this time with work in process.
    Edit: Remember that there’ll be orange light under the case (because of the fans). Also I need to paint the new part of the feets.
    Cya.!
  12. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    second one!!
  13. Koradhil
    9 Nov 2004
    I say without the mesh, because it makes it look too bulky and it doesn't match the square box theme of the rest of the case.
  14. identikit
    identikit Minimodder
    5 Jun 2004
    Agreed, without mesh. It looks like it's floating instead of grounded on a huge base.
  15. Bas van der Werff
    18 Feb 2007
    i really like the mesh, are you going to backlite it with orange?
  16. jegerjon
    10 Jan 2007
    Hmm, Koradhil and identikit, you're the first who's saying that. I've asked on a Danish forum, and there was no doubt that the mesh would look best. I'll let you give me your opinion, and then figure out what I'll do tomorrow ;)
    Thank you.
  17. jegerjon
    10 Jan 2007
    bas_van_der_werff, I'm not sure what you mean :D (I'm not THAT good at english ^^) But yeah, I hope that the light from the fans will shine out in the small holes in the mesh.
  18. Bas van der Werff
    18 Feb 2007
    That is what i mean, i think that would look very good :D
    Can you make a picture with the mesh in place and the led fan's on in the dark? so we can see how it looks like?
  19. jegerjon
    10 Jan 2007
    year for sure, I can fix that tomorrow. I would be glad to see the effect too :D
  20. elbarto241
    elbarto241 What's a Dremel?
    12 Sep 2006
    maybe you can design feet with a layed piece of lit acrylic and black alum. in the front.
