Case Mod - In Progress Project: NLM. FINISHED 11.08.07
Discussion in 'Project Logs' started by jegerjon, 6 Feb 2007.
  1. papeniglio
    papeniglio Minimodder
    5 Dec 2002
    Go for silver :rock:
  2. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Be different. Black Screws :hip:
  3. derbaum
    derbaum What's a Dremel?
    11 Apr 2004
  4. widmod
    widmod Minimodder
    9 Oct 2006
    black screws :thumb:
  5. Evenge
    Evenge Minimodder
    16 Sep 2006
    black
  6. ulysses Cazuquel
    ulysses Cazuquel Sex, Casemod & Rock'N Roll!!!
    29 Apr 2006
    One of the reasons that today I post my project in the bit-tech because it is a pleasure to be part of the same community of modder that accomplishes a beautiful that I always accompany
    Silver Dragons
  7. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    Definatly black imho. When I at the block with the black screws, I see somthing that looks professionaly done. When i look at the other, it still looks good, but the silver screws just don't give it that "look" if that makes any sence.
  8. Frido
    Frido Minimodder
    19 Apr 2007
    I prefer silver because they would stand out through the orange window.
    But if you got a transparent window instead of the orange one, you'd make people stare at your waterblocks with the orange plexi and details inside them, and THEN I'd choose black screws...
    Just my 2 cents...
    /Frido
  9. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    nice work on the case!
    i like the silver a tiny bit more than the black and they would be a little visible through the window. alot of black on the case with some shine here and there, no 1 fit'sthis theme well i think. i would like to see more shiny bits in the case. looking forward to seeing a glow through all the mesh at the base!
  10. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    Ok, I see that most people like the black screws. Thank you all for input. I'll go for black ;) Got something like 5hours for modding today.
    Cya around.,
  11. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    yay! black screws!
    anyways, this is one of my fav. mods on BT. keep up the great work!
  12. Tale Gunner
    Tale Gunner What's a Dremel?
    15 Dec 2006
    Youre looking good there friend. It really wont make a diff which one you go with as long as it puts a smile on you face. I liked the silver to go with the others but back goes with the connectors so its kind of 6 of one 1/2 dozen of the other!
  13. jegerjon
    10 Jan 2007
    Update 29 – Light part 1 – The front @ Monday the 2nd Juli 2007.
    Intro
    Finally I got a new update for you. I’ve actually done a huge amount of work (Yep! Soon I’ll be able to finish it, but still need the screen!), but I just want to teaser you a little :hehe:, and give the updates some time. The last things, are always the hardest to get rid off, because you’ve been extended them hehe, and damn I had a lot of troubles while trying to fix the light in the front! But finally I was happy with the result.
    I’m still thinking of how to make the light under the case look better, take a look in the end of this update.
    Lets have some light:
    Den sjove del
    Lined up – Here’s every thing I need, except of the soldering iron.
    I’ll be able to place leds all over the plate, except for here.
    The LCD screen is the wrong place, and I’ll not be able to place leds here.
    But let’s start soldereing, not much to show – bet you all know how-to :)
    That’s it. NO pictures in completely darkness, you have to wait for them to the case is finished, and I take the final pictures :)
    And last a picture of the light under the case. I don’t really think it fit the case with those light-spots under the case. (I know they aren’t completely straight, just need to adjust the leds).
    But I hoped you could help me coming up with a good idea, and how I could spread out the light a little more.
    Thanks to all who follows my mod, thank you.
  14. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    You could try putting a "diffused" strip of plexi over the leds under the case and try to even out the light more.
    This is looking killer man. Making me insainly jealous :p
    Wishing I can figure out what i want to do with mine. (tis a P180 so very limited on what I can/want to do)
  15. davidbacsik
    davidbacsik What's a Dremel?
    23 Apr 2006
    Actually, i think the light spots are pretty bitchin'. What I think would make them blend better (not sure why, and hate to suggest removing hard work) would to make the bottom of the case the same width as the rest, and chop off the "wings", so the spots project to the sides of the case onto the desk.
    P.S.
    Think I could use those spots come my mod?
  16. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Dang!! I think it looks great so far. But yes, smoked plexi should work. Maybe you have an off-cut laying around which you can "smoke" and then it a try.
  17. Teyber
    Teyber ******
    18 Mar 2007
    wow i just read that yoru 16
    holy sh!t man!
    I gotta learn how to solder LEDS man really bad...
  18. dacust
    dacust What's a Dremel?
    10 Mar 2007
    This has really turned out fantastic! Really awesome work.
    I like the dots in the base. But if you had something else in mind it may always bug you. If so, try Soulmage's idea. If you rough up one side, try it with the rough side up and then the rough side down. If it's not enough, rough up both sides.
    Anyway, absolutely first class work. Great design and excellent execution. :thumb:
  19. 500mph
    22 Jun 2007
    soulmage and dacust are right. that would be the best way to do it.
    still, it looks amazing!
  20. ComputerKing
    8 Sep 2006
    COOOOL! love it... enjoy your new case :D
