Case Mod - In Progress Project: NLM. FINISHED 11.08.07
Discussion in 'Project Logs' started by jegerjon, 6 Feb 2007.
  1. Damouse
    Damouse Thats no moon!
    27 Jan 2007
    ^^lol^^
    we should ask for a text version :D
  2. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    Thank you guys :rock:
    Damouse @ Oh boy that wouldn't be nice :hehe:
    I’ve always been follower of project logs with a lot of pictures, its so much easier to take a picture, and make a 1 line explanation, than to explain it with 5 lines :D
    Well back to the mod: I’m sorry, but I did just not enough work this week to make an update. Now I’m going on a little vacation, and I’ll first be back next week, hopefully You’ll get an update on Tuesday or Wednesday in the week after the next week ^^. Here I’ll finish the fridge so I can move on with some seriously modding.
    See you soon guys!
  3. Damouse
    27 Jan 2007
    Had a semi-related question....
    What was the stuff you used on the cracks? Googling synthetic metal gives me nothing.
  4. jegerjon
    10 Jan 2007
    Update 4 – Fridge Part 4 @ Tuesday the 27th February 2007.
    For word.
    All right I’ve got some more work done today.
    One update more, and the fridge should be finished :)
    The funny part
    First a picture from where I was last week (Trysil @ Norway). Man there was goddamn -20 degrees.
    Lets mod! So I’m going to use some foam (don’t know what its called in English) instead of the noise isolation. It seems as a much better solution.
    Now I put some “joint mass” on because: it hide the ugly foam, And it helps to isolate when the door is closed. I’ll paint everything when there’s nothing else left to do.
    I’ve rivet the hing, I’ll paint those to, as swell as repaint the whole fridge.
    And I’ve drilled a hole for the cables.
    Now the peltier and the coolblock are mounted.
    The backside looks good to.
    Well I ****ed the door up, so I’m going to make a new ^^ (Maan I love my mill :D)
    That’s pretty good.
    And the door is on, it fits very good.
    All right lets work on the little handle.
    After a meet with my mill it’s almost done, just need some filling and sanding, to make it fit the rest of the fridge.
    This is how it should be, it’s properly good enough ;)
    See you soon! Btw. Comments are welcome!
  5. Jipa
    5 Feb 2004
    Great work but the heatsink you're using just isn't gonna be enought for the peltier :/
    I think you haven't seen this one, it's my old case that had a peltier-fridge in it! http://metku.net/modgallery/detail.php?id=3956 I'll try to find more detailed pictures from that thing if you want..
    I had a AMD 64-heatsink and a cross-flow fan to cool the heatsink down, but it still got pretty hot! And the peltier was only 40-60 Watts...
    Your fridge sure looks better, but I'm just worried to hell about if that's gonna work.
    EDIT: I can't believe the host is still alive (it's one that came with our first internet-connection that hasn't been used for five years :jawdrop: )
    So there's images of the fridge-part
    http://www.nic.fi/~jvasama/compaq/peltier/
    And here's the complete project log
    http://forums.bit-tech.net/showthread.php?t=91718
  6. jegerjon
    10 Jan 2007
    So what you say is that the big box with 80mm fan you were using there wasn't enugh :O
    Well i bet i have to try my peltier out for some hours, just to check the temps. Thx for imput.
  7. Jipa
    5 Feb 2004
    Kinda enought as the peltier didn't die, but as the cooling power is all about temperature difference the peltier creates (let's say 40 c), if the hot side is 20 C the cold side is -20, but if it heats up to 35 C, you'll only be able to get the cold side down to -5 C.
    So the size really does matter ;)
  8. jegerjon
    10 Jan 2007
    I know that, the deffrence between the two sites on my peltier is 60C, så if i just can do the one side 65C I'll have the cold side at 5C which would be good :) But lets see.
  9. hellas91
    hellas91 What's a Dremel?
    18 Feb 2006
    That's a nice project! :hip:
    What mill are you using?
  10. jegerjon
    10 Jan 2007
    Thank you! I have no idea about what the mill is called, but I can find out tomorrow :) It’s an old machine but works very good!
  11. jegerjon
    10 Jan 2007
    Update 5 – The Fridges logo part 1 @ Thursday the 1st March 2007.
    For word.
    Today I got some more work done! When I’m working on the fridge, so I can give you guys the last update, I wanted to do something cool.
    There isn’t much to say. But I think you should enjoy the result, cause I bet it looks great! Next update will arrive tomorrow. I’ll paint the alu black, and hope it looks even better :D
    The funny part
    All right, first I’ve cut some 1½mm alu and some 3mm plexi out.
    I did a little sketch – hope you’ll understand it.
    I’ve put it in the mill.
    Now the hard work begin ^^
    Baaam. That’s nice!
    Lets go with the N.
    Done! It looks great to.
    …and when they are putted together.
    But we need the M.
    Über nitzel! – that’s the word!0
    I’ll let the last pictures talk them self.
    The alu is gone. It’s now ready for some paint.
    See you soon!
  12. Damouse
    27 Jan 2007
    very nice stuff! The letters are awsome!
  13. Jipa
    5 Feb 2004
    I want to have a mill! :(
  14. NysoO
    NysoO Handcrafted
    2 Nov 2006
    Those letters are kickass! Nice job :)
    The fridge also looks nice :)
  15. Nix
    Nix What's a Dremel?
    22 Nov 2005
    Love the concept jegerjon, you got any sketchup designs we can see that would show the final concept.
    Also you got a msn email i can use to add you. Got some mini-itx designs id like to show you that im going to work on for my next project.
  16. jegerjon
    10 Jan 2007
    Thank you guys I appreciate that.
    I’ll finish the fridge in the weekend, and I’ll also add some light to those letters, to make them kick more ass :D
    Edit: Nix you've got a pm :)
  17. its
    its What's a Dremel?
    7 Feb 2007
    OMG Jon.. Nice job you've just made here... Want some!!!! :D
    I'm looking forward to see the end result of this project, and when I'm thinking on your Custom Alu Case (that is really cool in my opinion), this can only be good!
    Also looking forward to see it IRL ;)... Let's find a date where i can see it..
    Cheers..
    Ohh.. And the plexi looks like the logo i made for you :D
  18. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Man, I reckon that could've looked so sweet with the metal still over the top of it - have the acrylic lit up by LEDs, then it'd shine out the sides giving a nice little effect.
  19. THEkorean
    THEkorean 42
    10 Jun 2005
    seriously.. keep the aluminum on top... just.. polish it or something, love the milling
  20. jegerjon
    10 Jan 2007
    Update 6 – Fridges logo Part 2 @ Friday the 2nd May 2007.
    For word.
    Today I got some more done (not very mutch) But eneugh to make an update :) I’ve figured out a smart way to light-up the logo..
    Lets do it. :D
    The funny part
    I’ve painted the alu black. I think it’s cool!!
    Some holes for the leds (3mm)
    Done ;)
    And some orange 3mm leds in. (this is not the final, I’ll do it correct when I’ve painted the backplate)
    From the good side ;)
    And with light on.
    Well It’s hard to get good pictures of this, but I think you’ve got an idea about how much they lighup.
    :) cool ;).
    That’s it for today.
