Case Mod - In Progress Project: NLM. FINISHED 11.08.07
Discussion in 'Project Logs' started by jegerjon, 6 Feb 2007.
  1. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Pitty the motherboard has a green PCB, I reckon this would've looked so much better had it been black. :(
  2. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    As I'll said i put some mesh over the whole mobo when all blocks are done.
  3. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    Looking good jegerjon. But sand your items a bit more uniform, there are a few tut's here on bit on how to do that. :)
    And yes you can legally buy beer at the age of 15 here. but not drive a car or vote before you turn 18. :/
  4. l0cke
    l0cke What's a Dremel?
    25 Sep 2005
    This mod looks awesome! and that beer cooler is sweet!
  5. Damouse
    Damouse Thats no moon!
    27 Jan 2007
    very nice stuff, especially the cooler.
  6. jegerjon
    10 Jan 2007
    Update 11 – The front part 1 @ Sunday the 11th March 2007.
    For word.
    Yes sir, now the front’s almost done! I really love it, and I think that it’ll look amazing with black brushed alu! Lets take a look.
    The funny part
    The alu sheet.
    And the plexi sheet.
    They fit very good.
    I got to separate my LCD to find the dimensions.
    After some milling.
    And then back to the mill again. The biggest job for the front is waiting.
    PERFEKT!!!!!
    Some closeups
    And when it’s on the case.
    Then the last holes. One for the bulgin button, and two for the tubbing which I want to go outside the case ;)
    A closeup.
    And the last picture. It look very good.
    Comments are very welcome!
    Cya!
  7. rowin4kicks
    rowin4kicks a man walked into a bar ...
    5 Feb 2006
    dude that looks amazing! your milling skills look great! hope this all comes together into a great mod!
    good luck
  8. Jipa
    5 Feb 2004
    I want that machine soooo much. Maybe I should go to school to study 3 years so I could get a job and use such @ work or at school.
  9. wbdog206
    wbdog206 not me
    15 Jan 2007
    excelint work on the block and fount plate.. :thumb:
  10. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    agreed ^^ looking very good!
  11. jegerjon
    10 Jan 2007
    Thank you guys! Tomorrow I'll fit the front on the case, and maby start with the h2o block for the peltierelement ;) But we'll see.
  12. V3ase
    V3ase What's a Dremel?
    25 Jan 2007
    It look fantastic
  13. jegerjon
    10 Jan 2007
    Update 12 – The front part 2 @ Thursday the 15th Mach 2007.
    Into
    Allright, to day i finished up the front.
    Btw. All the screws you’ll see is only for now, I’m going to order some black M4 umbraco screws!
    Lets do it.
    The funny part
    Allright, here’s the front I’m going to play with.
    It look horrible with the grey metal underneath there.
    Cut the big square out, and time for the dremmel.
    That’s a lot better!
    And from the inside, I’ll make a cover later ;)
    Those crappy rivets is just were I want to plant my plaxi.
    So why not make some 7mm holes ;)
    Now, that was better.
  14. jegerjon
    10 Jan 2007
    And then some sanding.
    And paintet absolutely awesome
    I just love the orange and black!
    I need to glue the two parts together, so I marked up where the LCD screen is.
    Lets glue.
    Ready to join.
    Then some pressure to make contact all over!
    And now! Good!
    Mhh, that’s nice.
    All right, lets drill some holes for the mounting.
    And also for the fan.
    Damn, I ran into this little problem. The nut wont fit in there, so I have to do some dremling later.
    Nice – right?
    And from the inside, after I putted on the glue, I’m 100% sure that I’ll make a cover plate..
    See you soon ;)
  15. Mr-IK
    Mr-IK Minimodder
    12 Mar 2007
    This project looks VERY awesome! I've been planning a mod by myself for some time, and alot of my idea's are very similar to yours! The Alu plating, and alot of the plexi under the alu, is something i'd like to do aswell!
    Ive got some new inspiration from this project, and damn you make me wish i had a drilling machine like that :C.
    Ill be keeping an eye on this project!
  16. jeffkim
    jeffkim What's a Dremel?
    20 Jun 2005
    man......it is awesome.......i love ur front plane........
  17. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    I like the design alot mate, i think you need to slow down and bring more perfection into the mod, the milling was nice, but the edge seemed chewed up, which tells me you were feeding the material to quickly.
    Again i love the mod, make me want to do something like it. :rock:
  18. wbdog206
    wbdog206 not me
    15 Jan 2007
    looks great really taking shape
    nice work on the front plate.
  19. its
    its What's a Dremel?
    7 Feb 2007
    Nice job Jon... Bad that I could't come and see it today.. Let's find another day..
    Love the black alu plate on the front, it's just... PERFECT! :D
    Are you making a plexi-window? Or?? :)
    Thumbs up! Cheers!
  20. B[x]
    B[x] What's a Dremel?
    3 Jul 2006
    I really like the orange acrylic with the black aluminum overlay. Five stars from me.
    You might have mentioned this earlier and if so, I missed it. However, what are your plans for your optical drive?
