Ok well this is my second project that im starting the first one still isnt completely done. But anyways i havent picked a name for it yet. Here are some pics of the case before the modding no modding has taken place yet. There are the pics of the case the modding will start shortly like in the next couple of days hopefully i got a lot on my plate and its going to take me a while to eat it all so keep checking up on it because it should be done fast.
If I'm not mistaken this is quite a large AT tower. Am I right? Will you modify it to fit ATX hardware, or will it stay AT factor?
Yeah its a huge AT tower and im going to mod it to fit with ATX hardware. So far i plan on cutting a window out of it and put a blower fan in the front of it and change the switch for the power. I dont know if you saw on the front of the case there is a Turbo Button and an LED im going to mod the Turbo Button to eather turn on a fan or a light and im going to use the LED screen for something i dont know what yet. IF any body has any ideas on what i could do to it that would be cool.
That seems like a good idea im going to have to check that out. Im also going to make one of the side panels sort of like a door something along those lines so i dont have to Unscrew anything to get it off.
