Project Nolio -Orange Flourescent Acrylic Case- Update!
Discussion in 'Project Logs' started by bahgger, 5 May 2005.
  1. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    It's like a big piece of candy. :hehe:
  2. djfrexx
    djfrexx What's a Dremel?
    27 Dec 2004
    blacklight .... oh ooooohw
  3. frodo
    frodo What's a Dremel?
    1 Nov 2003
    Hmm, is the only thing your using glue? if so i may have to have a little go with some scrap acrylic ive got lying around ;) need a new case for my mini pc!
  4. bahgger
    bahgger Minimodder
    13 Apr 2005
    Yes glue and structure-strengthening designs (e.g. slots for perpendicular pieces and triangular supports) :) The particular glue is Tensol 12 for acrylic-to-acrylic and simple epoxy resin for metal-to-acrylic :) Next week I'll be working on the aluminium exterior for a little bit of :D
  5. dubya01
    dubya01 What's a Dremel?
    22 May 2004
    So you haven't used any screws yet? That is sexy... will you be glueing the aluminum to the inside, or using screws?
  6. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    Omfg Godd:p I you good with uv and leds It will be f*u*c*k*i*n*g nice shiny case
  7. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    Strong swearing and blasphemy is not acceptable under any circumstances thankyou :eyebrow:
    <A88>
  8. bahgger
    bahgger Minimodder
    13 Apr 2005
    haha its ok alex...
    to dubya yeah nothing has been connected with screws yet. I couldn't find a solution for holding the fans so I chose to epoxy some screws on instead :) it works just as well!
  9. frodo
    1 Nov 2003
    :D i love it ;) i really need to get some acrylic now! want to make a mini cube like ;) to match my bigger one :D
  10. Captain Slug
    25 Nov 2001
    I would like to note that this project has inspired me to start work on designing the all-plastic case I've been thinking about for some time. I can't post a project log yet because I need to work on the design some more and copyright some of the strange mechanisms I've come up with but I just wanted to let you know you've inspired me to get off my but and make my dream-case a reality.
    Thanks :D
  11. Bradish
    Bradish What's a Dremel?
    7 Mar 2004
    Well I guess you should right a book about this case as an inspirational story, because I just got done ordering all my parts for my SFF Acrylic case for my currently naked matx system. Don't worry, its not orange acrylic. (Clear and Blue, boring I know, but w/e) :duh: And it will have an idenity seperate from yours ;) Anyway, I will have to continue watching this case with eager anticpation before I can start mine.
    -Brad
  12. <A88>
    10 Jan 2004
    Tbh I'm glad it's not orange acrylic, that's been this year's colour and it's beginning to pee me off as I'm doing one in the summer like that, but had it planned years ago! Yet projects like this are just gonna make mine seem crap :(
    <A88>
  13. waitandbleed
    waitandbleed What's a Dremel?
    4 Feb 2005
    Dang, Nice case indeedy. Would you be able to right a How-To on bending arcylic. Your bends are so even and nice. They are symterical with whats it suppose to be symtercal with. Like the HDD rack both sides look exactly the same. Keep up the good work!
  14. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    DAMN nice
  15. bahgger
    bahgger Minimodder
    13 Apr 2005
    I will indeed try to write up a mod guide when I can :) Bending of acrylic is actually very easy when you have a vice :) I'm guessing a g-cramp with two pieces of wood would do just as good, but two people may be needed to fix it before the acrylic cools :D
  16. bahgger
    bahgger Minimodder
    13 Apr 2005
    Okay guys here's the surprise I was hoping to spring onto you all. It came to my attention that if I were to carry out my current design I would need 20 metres of 10mm square aluminium rod :| Therefore I chose another design that will go on both sides. The top shall have the same design. Which one do you guys like best?
    1.
  17. frodo
    1 Nov 2003
    3 is my fav! just looks so damn sexy!
  18. lepre
    lepre Minimodder
    28 Aug 2003
    i like more 4 but i don't know overall the case how it will look..
  19. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    The second one is my favourite. Just a simple design. Less is more.
  20. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    I say you just leave it big, blank, and orange.
