Project Nolio -Orange Flourescent Acrylic Case- Update!
Discussion in 'Project Logs' started by bahgger, 5 May 2005.
  1. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    Nice nice nice wanna have it:D
  2. ginx
    ginx What's a Dremel?
    1 Sep 2004
    you acrylic skills own dude, this is so jeet :D
  3. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    You should if yuo find you have time, polish that steel-plate, that holds the card in place..
    Would glance nicely!
  4. ShinySwede
    ShinySwede What's a Dremel?
    6 May 2005
    i agree with razor cut, me like shiny ;)
  5. bahgger
    bahgger Minimodder
    13 Apr 2005
    Tried it guys. It's an aluminium plate and I sanded it with the highest grit sandpaper available to me, then placed metal polish.. The best shine I got was what you see on the inside of a Lian Li case.
  6. ShinySwede
    6 May 2005
    Well the inside of a Lian Li aint bad=) ...Maybe post a nice close up shot of the backplate, so we can se just how shiny it really is =)
  7. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    When I saw the first post I already thouht I had to keep an eye on this project. Now I know I was right, this is great!
    Sanding and polishing aluminium till it shines takes lots of time,( I know by experience ) but is possible.
  8. frodo
    frodo What's a Dremel?
    1 Nov 2003
    this is really starting to look AWESOME! it looks so well made, and it just all fits together nicely!
  9. bahgger
    bahgger Minimodder
    13 Apr 2005
    Pics pics pics :)
    enjoy!
  10. TomboyMS
    TomboyMS What's a Dremel?
    6 May 2004
    Impressive.
  11. Bradish
    Bradish What's a Dremel?
    7 Mar 2004
    It may just be me, but does your back panel bend inwards at the ends, and sticks out about where that clamp is? Cause from the pics it does, but it may just be one of those illusions... :worried:
    Keep up the good work, Lovin the orange!
    -Brad
  12. mcshaggy
    mcshaggy What's a Dremel?
    28 Mar 2004
    he said it got curved while bending the edges in, and imo it gives it a bit of character that doesnt do any harm
  13. Bradish
    7 Mar 2004
    Oh... I guess I'm more of a picture person... :duh:
  14. Firehed
    15 Feb 2004
    I really managed to miss this, but excellent work. It's all coming together very nicely, and looks a lot nicer than the prefab acrylic cases (including the C3 ones, which are really high quality from what I've seen). Keep up the excellent work!
  15. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Almost too orange :worried:
  16. Cowinacape
    Cowinacape What's a Dremel?
    26 May 2003
    Props on your level of craftsmanship! Great looking mod, and looking forward to seeing more, nice choice in colours as well.
  17. ShinySwede
    6 May 2005
    i think the curved back acrylic makes it look even better =) dont you love it when you make a mistake sorta and it turns out great anyways =)
  18. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    Bit of a random idea but if you were bothered enough about the backplate I've got a chrome one you could swap it for? I need one that I can paint so yours would do perfectly. dw if not, and keep the great work up (it's looking more and more like my planned mod by the second ;) )
    <A88>
  19. webbyman
    webbyman Hax.
    7 Oct 2004
    nice looking homemade case you have there :naughty:
  20. frodo
    1 Nov 2003
    Looking AMAZING!!! i LOVE it so much! its so well made, its really starting to get there now :D
