Case Mod - In Progress Project: Nvidia Stacker 832 - HDD and Cables - Feb 11th
Discussion in 'Project Logs' started by clownfart, 22 Sep 2008.
  1. clownfart
    clownfart Hardware Enthusiast
    23 Jul 2007
    Yes, cable management was the next thing on my list. I can't find the SilverStone Decathlon power supplies for sale anywhere. I'm going to have to either open up my current PSU, cut the cables down, or just make custom PCIe and SATA cables. I could order from the states, but thats gonna cost me. :(
    I get 38-40 load temps depending on the room temperature, for both the video cards and CPU. Those tests are done separately, I don't know what the temps are when both the CPU and video are under load. How might I test that? Orthos + ATItool?
  2. clownfart
    23 Jul 2007
    New Update
    Well my PC decided to blue screen every time I tried to play a game so I decided to get off my ass and work on my pc. I also installed those low noise adapters that come with Noctua's. The airflow on the S12s is noticeably lower, but still good enough to push air around the case. They are also dead silent. The P12s are also very silent, I can't hear them over the SB fan. My temps were only affected by a few Celsius.
    Thermalright HR-09 Type 4
    I got this little guy a while ago, but I didn't want to remove my mobo just to install it. I decided to lap it cause it had xbox hueg gouges in it.
    Cable Management
    I was tired of the 8pin CPU connector flopping around in my case. So I cut a little hole with my dremel. Very tight fit, it almost didn't reach the connector on the mobo. I also tidied up the rest of the cables, still a bit of work to do, but that'll have to wait for after the paint.
    Action Shots
    **** YEAH!
    Canadian Weather
    Too damn cold here. I'm glad I have a heater in my garage.
  3. clownfart
    23 Jul 2007
    HDD Mounting
    Still needs holes for the cables, but you get the idea.
  4. ry@n
    ry@n Minimodder
    31 Aug 2005
    Looks really great!
    I might have to steal your HDD placement idea, nice one ;)
  5. clownfart
    23 Jul 2007
    Thanks, but I got to give credit to Langer for that. :)
  6. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
    What do you have in the bottom front, that requires water?
  7. compmodder
    compmodder What's a Dremel?
    23 Dec 2006
    I believe that goes to the radiator???
  8. clownfart
    23 Jul 2007
    Correct. link to post with pics.
  9. b00mb1ast3r
    b00mb1ast3r Testdrive unlimited LoVeR
    25 Dec 2008
    great work so far!
    keep on going!
    i love this case stock and it will only get better with this Custom one :D
  10. nicky.82uk
    nicky.82uk What's a Dremel?
    19 Feb 2009
    you know your stacker did you put windows in yet also i'm doing mine now i was wondering will A.C. Ryan AcrylPanelâ„¢ 3mm - 480x480mm be okay pritty new to this ? i'm speeding around 2,000 for my water kit
  11. nicky.82uk
    19 Feb 2009
  12. Atheistmunk
    Atheistmunk planing future mod
    27 Feb 2009
    pretty nice work man
    your from calary? i'm from edmonton
    -Rohan
  13. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Nice mod. IS ti really that cold in Canada?:) I wish I could mve there:) Nice snowy winters and hot summers...
  14. The boy 4rm oz
    10 Apr 2008
    Very neat, turned out very well.
