Case Mod - In Progress [Project] NZXT Phantom Superleggera
Discussion in 'Project Logs' started by MilOk, 3 Jan 2011.
  1. DeadP1xels
    30 Nov 2009
    wicked base =o
  2. pistol_pete
    pistol_pete Air Cooled Fool
    7 Jan 2008
    Nice fabrication on the acrylic, I used lots of white acrylic in my mod but it ended up scare as I never could bend it well!
  3. MilOk
    MilOk What's a Dremel?
    18 Dec 2010
    thnks =)
    takes time to be able to swing right, but the parts that I painted too bent about it
  4. MilOk
    18 Dec 2010
    almost done =)
  5. KidMod-Southpaw
    28 Sep 2010
  6. MilOk
    18 Dec 2010
    :p
    k.3nny likes this.
  7. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    all coming to gether now, Ur doing an awesome job Milok!
    +rep :D!
  8. MilOk
    18 Dec 2010
    thnks =)
  9. MilOk
    18 Dec 2010
    black belt now let's see if it is right ...
  10. MilOk
    18 Dec 2010
    after drought, lack of a makeover but nothing more =)
  11. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    amazing mod m8 love the solid white colour and clean lines
    your spray line is a little scruffy... you should try tamiya masking tape ( you can find it at most model making shop) it might be a little thin, but just use it at the edge of the masking tape, its very good at getting crisp lines :)
  12. MilOk
    18 Dec 2010
    is no problem, easy to fix =) thnks
  13. MilOk
    18 Dec 2010
    a few more photos, as with acrylic
  14. Marcos_Viegas
    Marcos_Viegas Minimodder
    6 May 2010
    Awesome!
    PT mode on@
    Parabéns pelo trabalho, ficou realmente bom!
    Com um visual bem limpo e um ótimo estilo!
    Parabéns! :thumb:
    PT mode off@
  15. MilOk
    18 Dec 2010
    thnks,
    obrigado mas ainda nao esta acabado =) :p
  16. Rodhizzle
    Rodhizzle What's a Dremel?
    9 Apr 2011
    That looks pretty good man :D
  17. MilOk
    18 Dec 2010
    thnks =)
  18. MilOk
    18 Dec 2010
    thanks to NZXT =DDD
  19. MilOk
    18 Dec 2010
    Nzxt sentry LX =)
  20. grishenko45
    grishenko45 .
    6 Jun 2009
    that's a lot of work there - u recon it's possible to get a triple rad in the roof and a double on the floor? with a bit of modding?
