Case Mod - Complete ⭐ Project ONDA
Discussion in 'Project Logs' started by SaaintJimmy, 28 Feb 2020.
  1. SaaintJimmy
    SaaintJimmy Staff Lover of bit-tech
    6 Apr 2016
    Hello everyone!
    Glad to be back in business, after having moved workshop and installed my new CNC milling machine, which will assist me in the projects from now on :rock:
    The project I'd like to present to you today is something pretty special, based on the open air case Hydra Mini. It features an abstract theme and it aims at being a living room/design gallery element.
    I'll say no more and just let you imagine things as I go through the works! :D
    Firstly, I'd like to thank my sponsors for this project:
    HYDRA, PC HUNTER, HWLEGEND, ASUS ROG, OCPC GAMING, ALPHACOOL, SEASONIC, CABLEMOD.
    Let's give it a start then!
    First piece of material got under the machine's paws
    The first and last "crescent moons" will have closed pockets instead of holes because there will be rods holding them together and screws at the sides.
    One is missing, no more wood :duh:
    Base for the entire structure, with a nice chamfer and engraved Explore Modding logo
    All for now. Stay tuned guys :D
  2. SaaintJimmy
    6 Apr 2016
    Heyyyy everyone! How are y'all doing? :D
    I'm so happy to finally be back at the workshop, I've been quarantined for almost three months and then I had to deal with university exams, but now I'm here to blow some minds! :dremel:
    While I was working on the exams, I started making some time to get back to work on this project which was meant to be a quick one....
    and in that time I stained the wood in a mahogany tint, here's the result:
    Here's a test with three spacers that I made for the moons, but the rest will come later, there are 27 more to make :D
    My first attempt at the CNC with aluminum wasn't the most flawless ever, I got some melting and had to adjust some settings and make some trial and error. But I pulled it off eventually and these are a couple bracket that will attach to the moons and hold the 360mm rad!
    A pretty nerve-wrecking part was to drill 8mm holes on the edges of four of the moons which are 14mm thick. And this is what they are for:
    This is obviously just a quick fit test as the spacers are still missing therefore this is not a solid and final structure to continue working on. But I could get a clearer idea on how to proceed :D
    This is all for now but since I'm back modding full time, there will finally be some consistency. See ya! :D
    adidan, Aytos, lowfat and 5 others like this.
  3. Jean R built
    Jean R built Modder
    17 Feb 2020
    Nice one, it looks promising so far.
    SaaintJimmy likes this.
  4. Ianovski
    Ianovski Rawr!
    10 Mar 2011
    Ohhhh I love where this is going!
  5. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Ahh the return of one of my all time fav modders :D
  6. idpcmods
    idpcmods Minimodder
    30 Jun 2015
    Guess who's back... Back again... Looking great fam... Can't wait to see where you go with this one!
  7. SaaintJimmy
    6 Apr 2016
    What a warm welcome back you guys! :D
    Thanks for following, I won't disappoint! There are another couple of projects starting in the next weeks so keep an eye out :D
  8. SaaintJimmy
    6 Apr 2016
    NOT DEAD YET! Just too lazy to make constant updates :lol:
    Let's start off with a little custom bracket I made to mount the Eisball reservoir to the radiator. It already comes with a standard bracket but that didn't fit the look of this thing so I made my own
    Then I went to the custom panel that will hold the graphics card in an unusual position for the Hydra Mini: at the bottom! But since this Hydra Mini is hanging to the side, this means the graphics card will be facing at one side of the structure
    Here it is mounted
    Got some aluminum rods done to hold the structure together, as well as some tube spacer to go between all the moons to leave a 36mm space
    Fit test successful!!
  9. kim
    kim hardware addict
    10 Jan 2016
    Very elegant and original concept :clap:
  10. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Great idea ! A scratch-build with an embedded Hydra in an unusual position :clap:
    I already saw the final pics on instagram. :cooldude:
  11. SaaintJimmy
    6 Apr 2016
    Since this is a floating design, it's clearly not the sturdiest ever, in fact it sagged A LOT towards the right side, where there wasn't any support. So I added another aluminum rod, this time a longer one, to help support everything and keep it level
    I also fixed the top section of the Hydra Mini to the longer radiator bracket, using a small L-profile, so now it doesn't move at all
    Some adjustment was needed on the radiator brackets, and while the structure was half naked, I snagged a cool pic :D
    Now time to think about tubing, for which I'll use chromed ones for the first time, together with some acrylic as well
    But first, cable management! This was a tricky one because I had to manage all the cables from the PSU before mounting the Mini on the structure, BUT there were some important components on the structure, which needed to get their cables managed: fans and res/pump. So after having mounted the Mini, I had to make my hands small and sneaky to get to the back and tie everything up. I think I did well eventually and that last pic was the best I could do to show the cable management, because it can't be seen from any angle :D
    ivory2k19, Cheapskate, lowfat and 3 others like this.
  12. Flux
    Flux Minimodder
    11 Jul 2020
    What a piece of art!
  13. SaaintJimmy
    6 Apr 2016
    Thanks man, I appreciate it! :D
  14. SaaintJimmy
    6 Apr 2016
    Got tubing done as well
    Now it's time for some troubleshooting before wrapping up this project: this wood sucks. It's probably too soft for this application and the more I moved this thing around, the more it sagged and the holes at the base got slightly larger. So I picked some of this thick clear glue that should help keeping everything in place
    Aaaand it's alive! I didn't think this would look so good on a desk setup, but it actually looking killer sitting on the desk like that! Proud of myself :hehe:
    Got the RGB tamed and next step is final pics!
  15. Yargen
    Yargen What's a Dremel?
    1 Aug 2020
    Really great work, it’s astonishing what you did with the watercooling
  16. kim
    kim hardware addict
    10 Jan 2016
    Splendid :jawdrop:
  17. Defyant Mods
    14 Sep 2004
    Something so dam simple can be so dam sexy is again a credit to one of my all time fav modders ! :rock:
    How bout a tour of that ridiculously amazing work shop :thumb:
  18. SaaintJimmy
    6 Apr 2016
    Thank you so much guys! :D
    Might come once I start working consistently on my Youtube channel, should be soon enough! :naughty:
    Defyant Mods likes this.
  19. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Very good result, the ball definitely remember me Dragon ball! :grin::clap:
  20. Cheapskate
    13 May 2007
    You always make the prettiest tubing runs. The whole final result is perfect. :thumb:
