Case Mod - In Progress Project: Orange Monster, 26 July 2006; Wire routing blocks 16.3.2014
Discussion in 'Project Logs' started by Darkened, 26 Jul 2006.
  1. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    Very nice! I almost thought i have to drive over and force you to update. But you got lucky......this time!
    Keep it up!
    Cheers.
  2. Guest-23315
    Guest-23315 Guest
    sweet gorilla of manila!!!
    nice update!...
    also, you seem to be addicted to those Nexus Drive things....why??
  3. Darkened
    Darkened What's a Dremel?
    28 Feb 2004
    Thanks for the comments guys!
    That would have meant making a custom USB cable + the added clutter inside the case, believe me, there's already enough of that :D
    The case itself will be located under my desk, so that USB cable won't be visible, so it doesn't matter too much.
    @ Mankz
    The answer to your question is simple, IMHO, the Nexus Drive-A-Way is the best way to silence your hard drive. Since the drive is fully inside an enclosure and not just on some shock absorbers, it'll be really quiet and since the unit has also heat dissipation system your drive will also run quite cool. This is just my thinkings, I don't work for Nexus or anything :hehe:
    Keep them comments coming :thumb:
    Janne
  4. Guest-23315
    Guest-23315 Guest
    Ive got a Sunbeam one, it cost about £8, has an 80mm fan attachment, and is cromed!
    But i see your point....! Keep it up.!
  5. PA!N
    PA!N What's a Dremel?
    16 Jul 2005
    Darkened your mod is a huge inspiration to me, its just wicked :rock:
  6. Darkened
    28 Feb 2004
    Thanks guys and...
    @Mankz
    I have two of those sunbeam units in my basement, they are fairly nice, but they just didn't silence my drives enough, well I'm a bit high maintenance :hehe:
    Janne
  7. elliod
    elliod What's a Dremel?
    1 Oct 2006
    great work man and as it was sad we like it (very much) hope you get the right alu for polishing .
    keep up the good work
  8. Noni
    Noni What's a Dremel?
    8 Dec 2005
    Very nice, but Im not a fan of the acrylic on top.
    Have you got acrylic on both sides?
    Other than that, GREAT work! I love the placement of the HD.
  9. willettfx
    willettfx What's a Dremel?
    27 May 2006
    Janne,Thats awesome skills!!!Very nice!!!
    Gary
  10. customh
    customh conflagration.
    22 Oct 2005
    Absolute sweet. Keep it up!!
  11. Jeroenotje
    Jeroenotje What's a Dremel?
    10 Sep 2006
    Good work! Great eye for detail! Oh, I like the sidepanels :) . What did you used for polishing the aluminium?
    All I can is say is.. Keep on the good work!
  12. Evenge
    Evenge Minimodder
    16 Sep 2006
    Amazing, incredible, wonderful! :rock: :D
  13. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    im going to cry because it is coming close to finish! :( i love it!!
    A 1/4'' water cooling set up wud be great, with black tygon tubing! now where have i seen that before?!
  14. D3DAiM
    D3DAiM Slightly Stupid.
    3 Oct 2006
    I'm hoping to do something similar to this with my V2000, thanks for the inspiration.
  15. ZenX
    ZenX How are you gentlemen?
    5 Aug 2005
  16. cire9753
    cire9753 What's a Dremel?
    16 Aug 2006
    for the usb you can just get a pci slot usb 2.0 thing (so old comps can have more usb ports) and take off the back plate mount and plug it in...thats what i did.
    completely hidden
    and it cost around 1$usd from a bargin bin or somethin
  17. alonso_bistro
    alonso_bistro I'm just looking
    19 Feb 2004
    very professionnal , well done Darkened
  18. ssR
    ssR Carbon God
    11 Aug 2006
    great job Darkened. the assembled case looks sick. but on this pic
    the plexi bending looks a bit unperfect, is there anything can be done to fix that? dunno other than that it looks perfect but this is really hurting my eyes :sigh:
    just some constructive criticism, im sure you can handle it :thumb:
  19. DDarkSide
    DDarkSide What's a Dremel?
    24 Oct 2006
    I left for a while ,But I'm glad to see your progress..nice work indeed.. :blush:
  20. N.A.N.O.
    N.A.N.O. What's a Dremel?
    26 Oct 2006
    The acrylic is awesome dude :rock:
