Case Mod - In Progress Project: Orange Monster, 26 July 2006; Wire routing blocks 16.3.2014
Discussion in 'Project Logs' started by Darkened, 26 Jul 2006.
  1. Darkened
    Darkened New Member
    28 Feb 2004
    New front-end pt.1...
    You know what time it is!
    I've been really busy with real life stuff, but got something done also with OM.
    This week, boys and girls, we are concentrating on the front of the case :hehe:
    There has been some problems with a few things since I started using the Monster.
    Firstly and most importantly I have been having problems with the Plextor DVD burner. It works otherwise (installing Windows and other programs, watching DVDs and burned material in general), but I can't burn anything with it. Nero starts the burning sequence, but it jams at 1% (burning lead-in), but luckily it doesn't burn anything on the disk. This is either due to the motherboard I'm using (Asus A8V-E Deluxe) or the other and worse option is that the drive is DOA. And I don't think the shop likes the new shiny look of it if I tried to get a new one from warranty :hehe:
    Secondly there's a problem with my Ghost bootable CD, since the drive doesn't use ATAPI-drivers, the CD is lost and can't load Ghost :wallbash: That's not a malfunction though, just a matter of tweaking :hehe: And finally I tried ripping a DVD and it wasn't a success, I got 2x speeds and when I do it with my old IDE Plextor (712A) it goes up to 12x in no time and it gets the job done. This might also be due to the MB, so Plextor, I'm not giving up on you yet!
    The next step is to test the drive in my friends computer which is a month old, so if it was due to the MB, it should work with his computer. If not, I think it'll go down as a sad sad day, but I don't think I'll be buying another Plextor after that. And that is because I saw this Samsung SATA drive which was like 35€, that's pretty damn cheap when put against Plextor (about 100€). Would really like to hold on to my precious Plextor though...
    In the mean while I'll be rocking with my LG IDE drive that I have on my shelf.
    On with the problems...
    The DVD drive Lian Li bezel is also making my teeth grind. It works, but it makes an annoying sound when it opens, it's time to fix that...
    Here is the old one and it is to be replaced with...
    ...this, wait, I'm not done yet...
    ...much better :hehe:
    Here's a whole bunch I did yesterday...
    ...there's bezels for the DVD drive, Alphacool LCD and the last one is a surprise.
    On with it!
    Here's the new look for the Alphacool LCD, pretty nifty isn't it?
    Okay, so let's address the next "problem". Front ports are a good thing, but in my case they can be soo much better. Firstly let's take a look at what the front ports look like now.
    Do you see that amount of wire, me no likey! The problem is that I don't use the integrated soundcard so there's no place for the front audio ports. Also I don't have any use for Firewire ports and if I did there's two of them at the back of the case. Let's cut down on those wires, shall we...
    Luckily I found this, a small USB hub for 3,5" slot. It also came with an adapter for 5,25" slot, but since it's plastic it doesn't look appealing at all, scrap that! Let's bring out it's new companion...
    ...well at least it's aluminium :hehe:
    When put together, it looks much better and only one wire that I have to worry about, yippee! Though I'm not done with this either...
    While I was polishing the other stuff, I gave this bezel also a quick rundown :thumb:
    A tip follows: Now that I've polished quite a bit of alu parts, I've scrapped a few phases from the process. With this kind of "soft" alu I just remove the anodizing with a beltsander and then I attack it with an orbital sander to remove the deeper scratches. So no wetsanding anymore. Then I just put a polishing wheel in the drillpress and go over the part with cutting compound until there are no more scratches from the orbital sander. After that it's polishing compound with cloth wheel and finally a bit of handpolishing either with Mothers or AutoGlym. Figuring this out saved me hours of work :rock:
    That's about it for now, in the next part we'll be putting all of this together and back in the case. Stay tuned...
    Janne
  2. DDarkSide
    DDarkSide New Member
    24 Oct 2006
    All I can say is...SWEET :thumb: :rock:
  3. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    Very very nice job on polishing(as usual :D ). If you continue like this Jimms is getting rich! Haha!
    Keep up the good work!
  4. eegg
    eegg New Member
    29 Aug 2006
    nice!
  5. NysoO
    NysoO Handcrafted
    2 Nov 2006
    Very nice!! Can you take pictures of your tools and how the aluminium looks after each steps? :)
  6. chase
    chase New Member
    11 May 2006
    Sweet, homes.
    This means you're not using the plexi in the front?
    What is the "cutting compund" you are talking about? Wolfcraft?
    Petter
  7. Darkened
    Darkened New Member
    28 Feb 2004
    Q&A
    Thanks for the comments guys, keep them coming...
    @NysoO
    I can try it if I remember to take the cam to the workplace and remember to take the pics also :hehe:
    @chase
    Yes, the cutting compound I was talking about is the Wolfcraft one. And for the acrylic, I won't be using the part I made earlier, but there will be acrylic on the front...
    Janne
  8. Evenge
    Evenge Member
    16 Sep 2006
    I love it! :thumb:
  9. NysoO
    NysoO Handcrafted
    2 Nov 2006
    Thanks! That would be very nice.
    All I can say is; Keep up the good work! :)
  10. Darkened
    Darkened New Member
    28 Feb 2004
    Peripherals...
    What is this, two updates in a row :hehe:
    Well I thought that I'd make a small update on the peripherals and other equipment that I use. And if I remember correctly someone even asked me what kind of monitors I'll be using with the Monster. Let's see some of the stuff then...
    Firstly, here's a shot of my desk.
    And here we have my ADSL modem, memorycard reader and one of the Creative GigaWorks T20 speakers.
    For monitors I have two of these bad boys (well year ago they were quite bad :D), Belinea 20,1" widescreen TFT monitors. For now each computer (OM and the Server) has it's own monitor and I'm controlling both computers with the same mouse and keyboard using Synergy. Btw, the pic isn't that great, I had to take them against the sunlight trough the curtains, bare with them.
    I have two of these desks side by side and on the other table there is my Canon Pixma printer and my Skype phone by Linksys.
    Also there's a laptop there from time to time...
    ...and under the desk is a friggin' huge laser printer. :hehe:
    Finally there's my chair which is by far the best thing I've bought this year, no more back aches.
    That was it for now, I'll probably be back later on today with front-end part 2 update, stay tuned...
    Janne
  11. dragon-fly
    dragon-fly New Member
    9 Oct 2004
    holy nice peripherals! im jealous!
  12. ZenX
    ZenX How are you gentlemen?
    5 Aug 2005
    Yay @ the ADSL Modem, ZyXel something if i'm correct?
    PS: What ISP are you using? Saunalahti lags a lot in Vantaa from time to time...
    But a very nice mod, and it's always plus if you're Finnish =]
  13. antiHero
    19 Jan 2005
    Nice setup! What is that other case? Coolermaster?
  14. Darkened
    Darkened New Member
    28 Feb 2004
    Q&A
    @ZenX
    Nice to see other Finnish people here also. And yes, it's Zyxel 660HW-61 and my ISP is Sonera at the moment.
    @antiHero
    Yeah, it's a Cooler Master Praetorian and there's more about it in this thread, page 17. Check it out.
    Janne
  15. antiHero
    19 Jan 2005
    Yeah of course now i remember. I have to find that case somewhere its so nice!
  16. customh
    customh conflagration.
    22 Oct 2005
    Awesome setup! Can we get a full room shot?
  17. Solaris
    Solaris New Member
    26 Apr 2006
    I hope i'm not asking too much, just curious...what do you do for a living? :)
    Love your workspace btw :D
  18. Darkened
    Darkened New Member
    28 Feb 2004
    More Q&A
    @antiHero
    Try Only4pro, I think they still have that case in their selection...
    @customh
    I'll take one once I get OM finished and in it's own place, though there's not much to see, the other side of this room is my kitchen :hehe:
    @Solaris
    I'm studying at the moment, but I work as a bouncer and also making web pages and fixing computers from time to time.
    Janne
  19. Guest-23315
    Guest-23315 Guest
    Darkened, very nice setup indeed. Nice and cltutter-free!
    **EDIT..:: Not reading the post before**
  20. Supra55
    Supra55 New Member
    10 Oct 2006
    Lol he mentioned that on the last page at the very bottom.
