Project ORION by Koradhil
Discussion in 'Project Logs' started by Koradhil, 30 Apr 2007.
  1. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    Glad you like it so much CK. For you, apparently, the "wow" starts here :hehe:
  2. Mr. Oizo
    Mr. Oizo That yellow furry animal-thingy
    18 Mar 2007
    lol:hehe:But, the mod is cool. ;)
  3. Koradhil
    9 Nov 2004
    Even though I had to work all day, I got enough energy left to work on the front panel. The acrylic arrived today, mainly red tinted acrylic, but also some thick clear plates (for custom watercooling components) and a 4cm diameter tube (for a custom fillport / reservoir). I've made a copy of the aluminum front panel onto a piece of red tinted acrylic. I neglected to post that I had done the mesh for the front panel yesterday, but here's the final result. The three components for the front panel (1mm aluminium, 3mm acrylic, 1mm mesh):
    Which come together like this:
  4. Guest-23315
    Guest-23315 Guest
    Nice. I liked your waterblock workings in Mystique, so these should be as good!
  5. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    this case is really starting to come together in a great great way
    nice work
  6. KaotiK
    KaotiK What's a Dremel?
    2 Jul 2007
    Love that mesh. Will look great on the case :D
  7. Koradhil
    9 Nov 2004
    Hey guys, I guess you agree with me its time to start working on the project again. I had a break for some time for a couple of reasons, but mainly I didn't have time because I've been working almost fulltime the last month. Last week I got myself a notebook:
    Fujitsu Siemens Amilo Pi 2530
    - Intel Core 2 Duo T7100 1.8Ghz
    - ATI Mobility Radeon HD2300 128MB DDR2
    - 2x 1GB DDR2 PC5300 RAM
    - 160GB 5400rpm SATA HDD
    - 15,4" WXGA TFT CrystalView 1280*800px
    - Realtek Digital Audio (7.1 SPDIF)
    - Intel 56mbps WiFi IEEE 802.11 a/b/g
    - DVD+/-RW Dual Layer
    - 1.3mp webcam
    - SD/MS/MMC/MSPRO cardreader
    - Microsoft Wireless Notebook Optical Mouse 4000
    - Windows Vista Home Premium
    I'm now mostly working on my notebook, which allows me to take Orion apart for modding. So that's exactly what I did today.
    Also installed the GFX waterblock.
  8. HeXeN
    HeXeN Straight from Hell
    14 May 2006
    - Microsoft Wireless Notebook Optical Mouse 4000 - yuck :D
    OK.. i went trough all pages with this mod. Things U made are really good. I heard that U can paint smth and it will look like carbon fiber by using gauze(covering painting area with it an spraying)
    Good work!!
  9. Koradhil
    9 Nov 2004
    Thanks for the hint HeXeN, I might try that some day. For Orion though, I'm not going with carbon anymore.
    The mouse is actually quite good and very small, perfect for travelling, but at home I can't go without my MX518 :D
  10. Cyprio
    Cyprio G5 Supermodder
    2 May 2006
    Can't believe i missed this! Top quality craftsmanship Koradhil.
    Looking forward to seeing this completed.:thumb:
  11. Evenge
    Evenge Minimodder
    16 Sep 2006
    Nice! :thumb:
    That Epox mobo looks sweet!
  12. HeXeN
    14 May 2006
  13. Koradhil
    9 Nov 2004
    Thanks, I've seen that technique before. It isn't exactly carbon, but it sure looks good. It can also be done with something more rough such as a fruit net (the wire net in which you buy oranges).
  14. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    Great stuff so far Koradhil! :clap:
    If possible, I'd like to see more and/or detailed explanation of how you switched the motherboard tray around like that. Please and thank you! :D
  15. SPQQKY
    SPQQKY Evil Modder
    7 Jul 2007
    Looks great. Too bad about Epox going under. I used their boards almost exclusively since the EP-8KTA2 days. Keep up the good work.
  16. IanJackson
    IanJackson Photographer & Modder
    22 Mar 2007
    Sweet paint jobs on everything!!! Love how u painted the waterblock top/bottom! If only u could customize the pci-e, pci, etc... to what ever color u wanted... that would be a cool addition to a motherboard company like ASUS or Msi or something. keep it UP^ :thumb:
  17. Koradhil
    9 Nov 2004
    Thanks people, couldn't do it without your support :thumb:
    @gvblake22: It was actually extremely easy to change it to reversed-ATX. I just took out the tray, removed the rails, turned the tray the other way around and put it back in. The tray is now mounted only to the back side of the case, it doesn't slide in a rail anymore. Later on I will make the tray rest on a new rail or something else.
    Today I mounted the new front panel to the drive tray. To do this I took two pieces of L-shaped aluminum and mounted these to the front panel with two hex bolts each. Then I drilled holes in the drive tray to mount the L-pieces. This wasn't really all that much work, but it had to be measured perfectly in order for the front to mount flush in the case.
    I will have to make a new front for the DVD tray, because the original won't fit. The drive can be opened by pressing the aluminum beneath the DVD tray.
  18. ComputerKing
    8 Sep 2006
    WOWOwoWOWOOWOWOWOWOWOWOWOWOOOOOOOOOOOOOOOOOOOOOOOWOWOW nice project and cool ... good luck
    show me more :D soon :D
    I'm back to my home wooooooooooooooooooooooooooooooooooooooooot
    the wow starts again :D heheheh e
  19. Koradhil
    9 Nov 2004
    Been working on the CPU waterblock. I started out from the waterblock I made for my previous project, Mystique:
    This block was suitable for a socket A system, but wouldn't fit on the socket AM2 I'm using with Orion. Therefore, I had to make a new cover plate.
    And after an hour or so I got this:
    The block isn't ready yet, I'm thinking of spraying it black and adding a piece of 1mm aluminum to decorate the top.
  20. HeXeN
    14 May 2006
    if I would U a woud stic to the mesh theme even on this block:> BTW I LOVE drive bay U made its outstanding!
