Scratch Build – In Progress Project: OSIDIAS - Carbon fiber and 3D printed SFF (Jan. 2, 2020)
Discussion in 'Project Logs' started by craigbru, 2 Jun 2010.
  1. voigts
    voigts What's a Dremel?
    26 Apr 2006
    I'm trying to figure out what exactly to comment, but it escapes me at the moment. I'll just keep watching and maybe it will come to me.
  2. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Lol, I can honestly say that's the last analogy I expected to hear in this thread. Well played Rob. :lol:
    Yes, I'm much happier with the angles now. It took quite a bit of sanding to get them down, but it was worth it.
    Thanks man! I'm hoping for another update by tomorrow. :D
  3. Pieze
    Pieze What's a Dremel?
    7 Jun 2010
    wow your setting a new standard. Lol damn you! :jawdrop:
    now instead of 2 categories being Mod and Scratch. There gonna have to come up with another one. I vote the over achiever. :rock:
    good work man congratz on the body coming out so well. :thumb:
  4. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    Is it tomorrow yet? :)
  5. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    is it time yet?
    is it time yet?
    is it time yet?
    is it time yet?
    is it time yet?
    is it time yet?
    is it time yet?
    this tomorrow stuff is killing me
    is it time yet?
    is it time yet?
    is it time yet?
    is it time yet?
    is it time yet?
    is it time yet?
  6. Guest-23315
    Guest-23315 Guest
    :waah:
  7. shomann
    shomann Minimodder
    5 Sep 2003
    Craig, you are the wrong person to call anything overkill. :D
    It's still looking great, and I think that orange will look great next to the carbon black.
  8. craigbru
    28 Feb 2008
    Wow, thanks! I'm not sure I'm worthy of that praise yet. I've still got so much work to do. Lol, I'll admit that the CF is getting all of the attention, but the internals are where the real work will happen.
    Lol, you guys are killing me. I'll see what I can get done for you tonight... That's US central standard time. :D
    Touché! I guess not. If it wasn't for overkill, I wouldn't have nearly as much fun modding. :D
    Yes, the orange and black are going to be a killer combination. I was initially disappointed that the kevlar lost it's brightness with the resin. However, after looking at it last night, it's got a deeper, more sinister look that I'm really starting to love. It somehow really fits the name OSIDIAS.
  9. craigbru
    28 Feb 2008
    If it weren't for pictures like the following, I'd take the Kevlar/CF blend, and make it disappear... Yes, it's a royal pain to work with. I knew it would be, but until you are actually working with it and trying to make it do what you want, you have no idea...
    It doesn't like to cut cleanly, no matter the process. The Kevlar fibers really have a mind of their own. I've found that I get the best results if I start cutting with a metal carbide cutting wheel. That cuts quickly, but not cleanly. I then followup with a reinforced cutting disk. This cuts much more cleanly, but it's slow. I can't take much material off with each pass. After that, I use a file to straighten the cuts. Then finally, I finish up with a 320 grit wet/dry sand paper. This does a decent job of cleaning the edge up, but it takes a light touch. So, that's one heck of a process for a single cut!
    Time to cut! I used a yardstick as a straight edge, and followed up with my line taping method.
    An hour later I had two sides done... This is gonna take a while. Lol.
    The boy 4rm oz likes this.
  10. talladega
    talladega I'm Squidward
    18 Aug 2007
    i came bucketz!
  11. craigbru
    28 Feb 2008
    Lol!
  12. Cheapskate
    13 May 2007
    Ah, so the materials have a different texture/feel to them. Would you say the CF is 'crunchy', and the kevlar 'chewy'?:D
    I wonder if a table saw would work, or tear the hell out of the material...
    You need to take your new panel out in the sun for a photo. Indoor lighting isn't cutting it.
    (My puns suck.:duh:)
  13. barry99705
    20 Apr 2008
    Craig needs to invest in a laser cutter..... :D
  14. disturbed13
    28 Nov 2008
    x2
    i was thinking that he needs to invest in a water jet
    i have a feeling that it would give a good clean cut the first time around
  15. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    na, the waterjet would blow the weave apart rather than cutting, you've got to remember the water and its abrasive is doing close to Mach 2 upon leaving the nozzle, that is a help of a lot of pressure behind it, also the biggest problem with the weave is sealing the cut ends, they tend to wick water like crazy.
    also craig, ever think of getting an ultrasonic cutter? Works on solids as well, seen people cut CD's no problem
  16. Shadow703793
    Shadow703793 What's a Dremel?
    5 May 2009
    The Kevlar looks MUCH better than I thought.
  17. talladega
    18 Aug 2007
    maybe a tile saw would work?
  18. Langer
    Langer Jesse Lang
    24 Jan 2004
    Kevlar is a b*tch to cut once it's been formed and set.
    At the plant we have a tablesaw with 2xblades. The first is massive, ~30"diameter, which makes the cut - the second is slightly thicker and much smaller, ~6", and it cleans the cut.
    Both have special blades which need frequent changing and both spin at ungodly speeds.
    Your best bet with kevlar is waterjet.
    -Looks great BTW- you're doing a great job. I'm loving this case mate... loving it!
  19. disturbed13
    28 Nov 2008
    langer agrees with me
    ive seen a commercial for a local machinist shop and they have a vid of the water jet cutting through
    2 or 3" of solid metal
    so if it can cut that
    i had a really good feeling that it would make short work of CF and Kevlar
  20. murtoz
    murtoz Busy procrastinating
    9 Apr 2008
    nice thx but not mah bukkit
