Scratch Build – In Progress Project: OSIDIAS - Carbon fiber SFF! (A new direction, Aug. 28 2019)
Discussion in 'Project Logs' started by craigbru, 2 Jun 2010.
  1. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Well, here it goes guys. After more than a year of planning, I've decided to officially to start Project OSIDIAS. Granted, I still have other projects I'm still working on, but I don't want to delay this any longer. I can't promise daily updates, but I have a feeling you all will keep motivated to keep my work as updated as possible.
    OSIDIAS will take everything I've learned from my Rogue project, and double it, in both scope and ambition. I've got some pretty unique things I'll be attempting here, and I've got no assurances that everything will work out as I've planned. That doesn't matter though, as I enjoy the challenges of problem solving on the fly. Even though at this point, almost every detail of the case is planned, there are still going to be things I decide to change. However, due to the way the case is designed, there are certain things that must remain set in stone. The overall exterior of the case and the carbon fiber shell for example.
    So, where do we begin? Well, for those that may not have been following along up until this point, this video gives the best project overview. If you've got 20 minutes to spare, this should catch you up to speed. You can also read up on my planning thread here.
    Now, although this is the first official post of the project, I've only got a few pics to show you. Don't worry, I've got more incoming, but I this should get things started. :D
    This case will be the first time I move away from aluminum as my primary construction material. There will still be plenty of it in this case, but I figured it was time for something more exotic. That's where carbon fiber comes in to the picture. Actually, carbon fiber, as well as a carbon fiber/kevlar blend. The carbon fiber will be placed around molds that I'm currently building, and them vacuum bagged. This is a proven technique for manufacturing, but the first time I'll be attempting it. There aren't many computer mods made from CF, let alone molded as in what I'm trying, but that's where the fun part comes in! I've got to give full credit to MKmods for his advice and input regarding working with carbon fiber. With any luck I'll not end up with a very expensive mess on my hands...
    I mentioned having to make the molds, and that's where the following pictures pick up. Thanks to the help of my Romaxx CNC machine, I was able to accurately cut out a few pieces of the OSIDIAS core. These pieces will sit in the center, while an aluminum 'clam-shell' sits around it. After the carbon fiber and vacuum bagging, the idea is to push the center core out, and then remove the shell from the inside. This will leave a solid CF case, from which I will make the needed cuts.
    Here are the blank pieces of MDF ready for the Romaxx CNC.
    After the CNC cut...
    And finally, I've got a stack of them.
    Next up, we've got the core assembly!
  2. disturbed13
    disturbed13 New Member
    28 Nov 2008
  3. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    I just ordered some styrofoam blocks for my next project molds. But I chose the cheaper, fiberglass way...
    good luck with CF!
  4. shomann
    shomann New Member
    5 Sep 2003
    I am with disturbed13. Subbed. I would double-sub if I could.
    Good luck craig!
  5. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    Awesome! Been waiting for your next project to officially start. I'm grabbing a front row seat this time! :D
  6. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
  7. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Score, I can't wait to see more
  8. hurv
    hurv New Member
    30 Oct 2009
    I am psyched to see this happen!
  9. stonedsurd
    11 Mar 2009
    *subbed*
  10. talladega
    talladega I'm Squidward
    18 Aug 2007
    WOOOHOOOO!!!!!
  11. craigbru
    28 Feb 2008
    Glad to have you aboard!
    Thanks man! I think I'm more concerned about things like the resin drying properly than working with the CF itself. It would be costly if I screwed up, but that's part of why I'm making a mold I can reuse. Just in case...
    Thanks! Just sub on every forum in which I post. That should keep you busy for a while. :D
    Thanks Brian!
    I appreciate the enthusiasm guys! This is what keeps me motivated and moving forward! :thumb:
  12. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    OH GOD OH GOD :worried:
    i've been waiting for this for so long :D
    good luck ! can't wait to see more
  13. disturbed13
    28 Nov 2008
    whoot
    i was the first :D
  14. sb1991
    sb1991 New Member
    31 May 2010
    Sounds like this is going to be very impressive!
  15. MrWizard
    MrWizard New Member
    5 Feb 2008
    Honestly, I saw your name attached to a project log and just subscribed because it's the right thing to do.
  16. craigbru
    28 Feb 2008
    Thanks! It has been a while, hasn't it?
    Lol, somebody has to be. :D
    Thank you! I try and aim high. The fun part is trying to live up to my crazy ideas.
    Haha, thanks for the kind words.
    So, are you guys ready for another update?
    My last post left off with the cut MDF pieces for the core of the case. What I needed now was some simple way to fasten those pieces together, while still providing strength. I went round and round with possibilities until I decided on the following method. It all started with a trio of 22mm holes courtesy of the Romaxx.
    Thanks to the CNC's accuracy and repeatability, I ended up with 6 pieces just like this.
    With the first piece laying down, I tapped 3 sections of PVC pipe into the holes. The fit was just tight enough that there was no movement once in place, but taps with a hammer could still allow any needed adjustment.
    Now finally, here is the assembled core. It's lightweight, yet very strong. The PVC pipe not only serves to hold the structure together, it also has a secondary purpose. Since the carbon fiber will be vacuum bagged, the pipe will allow for pressure equalization between the front and rear of the mold.
    With the core done, I'll be moving on to the 2 part aluminum shell that fits around it. Thanks for reading!
  17. shomann
    shomann New Member
    5 Sep 2003
    I just realized that I DID double sub ;) (For those that don't know, Craig maintains his own forums)
    Incidentally, you don't have to ask if we are ready for another update Craig - we are, even if you post them every hour ;)
  18. voigts
    voigts New Member
    26 Apr 2006
    This looks like it is going to be a fun show to watch. :jawdrop:
  19. Fabou
    Fabou New Member
    22 Apr 2010
    Since everibody seems so excited I join the fun. Great start.
  20. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    This will be fun and I'll be watching! :thumb:
