Case Mod - Complete Project Osmium
Discussion in 'Project Logs' started by WanV, 27 Oct 2017.
  1. WanV
    WanV What's a Dremel?
    23 Dec 2016
    Hi,This is my third case mod
    Link for first mod:http://www.overclock.net/t/1619098/case-mods-first-time-mod-project-sinanju#post_25729818
    For 2nd :http://www.overclock.net/t/1624567/sponsored-project-honor-complete/20
    For this time i try to mod based on osmium colour but its hard to get dark chrome colour so i just opt for what i got
    Before That i would really like to thank you to all those sponsor and trust for my case mod and first sponsored project
    Thermaltake = http://www.thermaltake.com/
    Kingmax =http://www.kingmax.com.tw
    [​IMG]COVER 1 by Wan V, on Flickr
    Here the Spec For This Case Mod
    Thermaltake:
    View 71TG
    P1 Pacific Black Pump
    Pacific Flow Indicator 2
    Pacific Temperature Sensor
    Pacific W4 Water Block
    RL11 Reservoir
    TT Sleeve Mod Cable Pack
    TT PREMIUM Plus FAN 3 PACK RGB
    V Tubler PETG TUBE 12mm
    Thermaltake Bending KIt 12mm
    Thermaltake Dye And Coolant
    Some TT Fitting 90 Degree Dual OD,Compression Fitting,Angle Fitting,And Extender
    M-pro New fitting
    Other parts
    Intel Core i7 6800k
    Strix X99
    Kingmax Zeus Dragon 4x4Gb
    Kingmax SSD 240GB SME32
    Design
    Will Be upload
    Thanks[/quote]
  2. WanV
    23 Dec 2016
    Testing new thermaltake Dye
  3. WanV
    23 Dec 2016
    Spraying The Frame And Part
    Front Panel i cut some part for the mod
    Top Panel
  4. WanV
    23 Dec 2016
    Also Spray some res and pump part
    need to sand it first since its pretty glossy
  5. WanV
    23 Dec 2016
    Finish product since its pretty hard to find people who can do chrome plating i just use some aerosol spray looks pretty good but the spray its pretty fragile
  6. LePhuronn
    LePhuronn Minimodder
    6 Oct 2016
    some matte clear coat should help protect your chrome paint. looks great
  7. WanV
    23 Dec 2016
    thanks will try it, its my first time trying to play with chrome is it any diff if use gloss clear coat compare to matt?
  8. WanV
    23 Dec 2016
    because this case mod base on chrome so i try to mirror finish all my part
    sanding
    you can see how rough it is
    done sanding with 360 grit
  9. WanV
    23 Dec 2016
    polishing with meguiar plastx
  10. WanV
    23 Dec 2016
    custom reservoir since i dont have access to cnc so i just user laser cut machine and will do 3 layer front res and floor
    even inside i will sand it through to get mirror finish
  11. WanV
    23 Dec 2016
    Done polish some part
    tt W4 Waterblock
  12. WanV
    23 Dec 2016
    MODDED tt w4
  13. LePhuronn
    6 Oct 2016
    Beautiful work.
  14. WanV
    23 Dec 2016
    done Back Frame
    [​IMG] [​IMG] [​IMG][​IMG]
  15. WanV
    23 Dec 2016
    Starting to make my 3 layer Front custom res
    im using white rubber ring
    Rear Nut
    front screw
    Finish Product
  16. WanV
    23 Dec 2016
    Dissamble my waterblock to polish
    done sanding with 2000grit
    my ram block which i polish
    SRY FOR LOW QUALITY PIC MY CAMERA BODY GOT PROBLEM
  17. WanV
    23 Dec 2016
    Custom Floor Channel
    transparent silicone ring
    you can see im polishing inside out to get mirror finish
  18. WanV
    23 Dec 2016
    also im modding my own gpu waterblock
    disassembly
    since some of the part got frosted finish so i start sanding it with 400 grit and finish all of it with 2000 grit
    done polish and some mod if you realize what it is
    im changing the original plate to transparent acrylic and and all the bezel and polishing all by hand just not satifies with the screw need to use 12-13mm but i only got 16mm should bought more
    kim likes this.
  19. WanV
    23 Dec 2016
    Hi sry for long time to no update since im quite bz working nowday here my lates tprogress
    this is the right side
    left side
    back panel
  20. BU5H W00K1E
    BU5H W00K1E Minimodder
    18 Nov 2017
    Nice build so far! I love the view 71 I’m currently doing my build with the same case.
