if you have a program like Fireworks, you can do a batch process, in other words, give it a list of all your pics, and it will resize the lot automatically
Paint Update 26/06/06 Hi just a small update. i have almost finished spraying my case so i should have some pics up to night. (the correct size ) and i dont know what you will think but i love the matt black finish i have given then inside
Hi just a quicky i have spent the better part of 4 hr's resizing the pictures in my log so hope they suit (if you want links to the high res versions just notify me and i will up some links up)
any good motor factors should be able to get some in, may not have them in stock... or a car panel shop... hth...
Quick Update 30/06/2006 I have just this second recived three Bulgin Blue Ring Illuminated Vandal Resistant Puch Switches from a Farnell InOne (they do next day UPS delivery for free) which worked out cheaper then Kustom PC or any of the sites that stock the alpha cool ones. I also got a reply to an email that i sent to a plastic fabrication company to day, to see how much it would cost to cut the parts need for the res. this is the reply Im happy with a cost like that if it would be laser cut/milled to my exact drawings. were as if i would cut it out it would not look as good. casue i would put a gapping hole in it or something along those lines. Another good thing that happened to day i got conformation that my devivery of £600 worth of MoBo and GXF is going to arive on Monday.
I have got my pop rivets on order from a metal work shop near me called quick sharp. they should be with me on the monday/tuesday then that is case respray complete
Product Update 03/07/06 Hi All My GFX and MoBo arrived Via citylink to day from Scan This is my New SLi Kit My New ASUS A8N-SLI/PREMIUM NF4 SLI, S939, PCI-E (x16), DDR 400, SATA I, SATA/IDE RAID, ATX In the Box Out of the Box Now with the passive cooler off Now with the Alphacool Heattrap Regcooler Asus SLI Motherboard Capacitor Cooler Now the best Bit the 2x 256Mb XFX 7900GT Extreme,Mem 1500 MHz, GPU 520 MHz, 24 Pipes, Dual DVI-I HDTV, VIVO In the Box Out the Box And now for a quick look at the alpha cool water blocks I have only one problem though, the SLi North Bridge cooler does not fit because of two Capacitors sitting to close (and yes i have tryied taking it apart and moving the mounting plate around, but i think i can get a normal north bridge cooler to put in its place.
I really love Antec cases, and this looks like a very nice mod in the works. I especially like the fans! I'll keep an eye on this one.
Arrrrrrrrrrrrrrrrr!!!!!!!!! It is to hot to think i have gone threw 5 PCB strip boards, because i keep on making stupid mistakes.
I think what timmy was trying to say is: "Its very hot today, and muggy. I'm finding it hard to concentrate, thus, making silly mistakes that i may in cooler weather not make." silly timmy! go swim in your swimming pool. Your butler can bring you a nice beer.
Yer I would but my new house does not have a pool and my "Butler" is on holiday P.S will thank you for making sence of my rants
(he used to have house called the White House... No joke, our timmy's address used to be: Timmy The White House some place in england I0WN J00 Timmy is the president!)
Yes i did live in The White House, (in a small village in the UK). and yes it did have a pool but i was joking about the butler. and if you want to know how rich i am, i drive a rusty 15yr old vauxhall NOVA.
