Project P160 Blue Water
Discussion in 'Project Logs' started by trati629, 30 May 2006.
  1. Guest-23315
    Guest-23315 Guest
    i dont even have a car....
    nice kit, and good looking mod...
    PS- im only 14... and in your sig, you spell duel DUAL
  2. trati629
    trati629 Can I Fix It? :$ Well Yes??
    13 Jun 2005
    Thanks for that. my spelling is really bad
  3. CursedBlad3
    CursedBlad3 What's a Dremel?
    30 Jun 2006
    trati for someone who says he isnt that well off you have alot of money to spend on modding lol
  4. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    Brwahahaha!
    Tims spelling is terrible, but he can make a mean plate of natchos!
  5. Guest-23315
    Guest-23315 Guest
    CursedBlad3, i dont honestly thinks he's all that rcih, he has just put his PC high up the list of priorites.....
    I would but my girlfriend costs me far too much.... im stuck with a rubbish clocking 146....
  6. trati629
    13 Jun 2005
    Mankz has got it down to a T.
    I don't have much money but what i do have gets spent on my PC.
  7. will.
    2 Mar 2005
    I just got a job, and i'm making more money than i have ever had in my bank ever per month! All of it (whats left over after expenses anyway) is about to go on my pc! I might even log it, but i don't think i will mod it too much..
  8. trati629
    13 Jun 2005
    Will please Log it or even just sick some photoes in the gallery after you have finished (get water cooling or even phase cooling now you have the money)
  9. trati629
    13 Jun 2005
    Question Time?
    Im trying to find a set of water cooling blocks that can run from a 8mm ID system but then be able to be upgraded to a 1/2" or 3/4" sytem when i get enough money? would alpha cool water blocks do the job?
  10. trati629
    13 Jun 2005
    Shopping Update 08/07/06
    i dont need the question above answered i have done it for my self and i have just ordered the parts from alpha cool. :brrr:
    Pump
    Chip Set
  11. trati629
    13 Jun 2005
    hi this is a small update to give you a quick example of how the water cooling will be in my case in both phases
  12. will.
    2 Mar 2005
    mmm, spaghetti...
    i've always thought that if the water goes through one gfx card and then another, the second one will get warm water, thus lesser cooling. Wouldn't it be a better idea to have a Y connector followed by a valve to stop it circulating and then another Y connector to join it again... This way both cards get cold water.
    That way it could go:
    RAD
    PUMP
    GFX Card 1 - GFX Card 2
    (the little square chip..)
    Resivoir​
    if u have the split right after the pump then there would be no worries about one card getting more water than the other as the pressure would be pretty even there.
    just a thought.
  13. Atomsk
    Atomsk What's a Dremel?
    13 Mar 2004
    Not really it wont raise it too much(1-2 degrees) and if you do the Y connection 1 of the graphics cards will get more flow than the other because water takes the path of least resistance so that will change temps more than just warmer water.
  14. yahooadam
    yahooadam <span style="color:#f00;font-weight:bold">Ultra cs
    21 Mar 2006
    also each gfx card gets less water, so that will also raise thempreatures, i dont think it makes alot of difference, and you will just end up with both cards being hotter
    Also, heat froms from hot to cold, the water is unlikely to deposit its "heat" into the waterblock
    dont forget the Y splitter adds yet another piece of resistance in the loop
  15. trati629
    13 Jun 2005
    I am going to keep my system as i have stated in the loop which has a dual loop
    RES
    Pump***Pump
    CPU***GFX GFX
    Voltage***North
    Block*****Bridge
    RAD
    RES
    This is so that the pumps have an unrestricted flow of water (cause my rad has a small ID)
  16. trati629
    13 Jun 2005
    I have just started on the final design of my res so that the CAD drawings can be sent of to mk plastics so it an be laser cut and etched.
    i also got my parts from alphacool this morning in the post ( i have assembled the blocks on to the mobo so will post some pics tonight
  17. will.
    2 Mar 2005
    :( you keep promising pics.... i don't see any!
  18. trati629
    13 Jun 2005
    im sorry i get to involved with doing thing to my case i forget to post the pictures up, it is only when i get to work(without the pictures) that i relive i forgot to post them. but i promise that the pictures will be up tonight as well as a new render of my res that will be sent off to mk plastics for them to give me a quote. (and i might just find out what the name of one of the best plastic glues i have ever used)
  19. trati629
    13 Jun 2005
    Photo Update 15/07/06
    Hi all
    This is a pic of my asus mobo with the chipset water block and the reg coolers bolted on
    see i said i would have photos up tonight will
  20. trati629
    13 Jun 2005
    Oh i got my countersunk pop rivets to day, I ordered the wrong ones 4x16 insted of 3x6 (well when I said "I" I mean my dad orded the wrong ones and i have open the box so i can not take them back) does any one want to buy them from me at a reduced price i have 500 of them
