Project P160 Blue Water
Discussion in 'Project Logs' started by trati629, 30 May 2006.
  1. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    I want to do an intricate system of rads I think maybe 3 3 fans maybe 2 parralleled in the system with 2 Ehiem 1046 mod. pumps.
    2x vortex Bottom Res
    PUMP PUMP
    ACRYLIC SQUARE DISTRIBUTOR
    GFX Hard drives Cpu
    / / Msofets/Northbridge
    _________________________
    5.25" bay res/indicator
    vortex.
    That system is flawed but it would be cool.
  2. trati629
    trati629 Can I Fix It? :$ Well Yes??
    13 Jun 2005
    Photo Update 17/07/06
    Hi all
    Just an up date on what i did today. it was not much but it took me most of the day to complete but with a little bit of braso and the polishing bit for my dremel :dremel: I got it prity shiny yay :clap:
  3. hydro_electric_655
    13 Jul 2006
    I would be careful using a dremel for a water block I have used a polishing compound with a dremel and ground down about 1/64th of an inch off a steel knife so you could easily create unevenness.
  4. customh
    customh conflagration.
    22 Oct 2005
    I agree, you should get peices of sandpaper and get an extremely flat surface (like a glass panel) and work from 1000 grit to around 3000 or something. That will create the most even contact surface to get the most contact with the cpu.
  5. yahooadam
    yahooadam <span style="color:#f00;font-weight:bold">Ultra cs
    21 Mar 2006
    somone made a small guide somewhere how to do the blocks, but it basically said that you should put the sandpaper on a block of MDF, you have to have a flat surface for the sandpaper
    Fake Edit:
    http://forum.pcstats.com/showthread.php?t=36146
    Nice little guide :)
  6. trati629
    13 Jun 2005
    Im happy how it is and i found that as long as i kept teh dremal moving it did not leave any dents/uneveness
  7. trati629
    13 Jun 2005
    Shopping Update 20/07/06
    Hi just spent some more money at alphacool :clap:
    This is what will arive in the post soon:
    • WAK CPU Alphacool NexXxoS XP Bold Socket 754/939/940/FX/Opt./AM2
      Click for Larger Image (Link to alphacool.de)
    • Water additive power fluid Blue UV
    • WÄRM Thermal paste Alphacool Paste LM
    • Screw connector AG 1/4' on 10/8mm
    • Hose PUR 10/8mm UV-Active Blue
    I just love alphacool water cooling parts :thumb:
  8. trati629
    13 Jun 2005
    Paint & Case Update 20/07/06
    Hi all Just a small up date today.
    Today I finished riveting my case together :clap: and so i dicided to give it a wash and wax
    I have also marked out ready for the jig saw some sheet aluminum which will be the new front to the case (it will sit behind the res)
    I went shopping to B&Q at Lunch and go me some L and Some Square U sections so that i can build a devise to hold 2 pumps
  9. yahooadam
    21 Mar 2006
    and wet yourself in excitement ?
  10. Oompa
    Oompa What's a Dremel?
    7 May 2006
    Don't forget to put the memory in 2 of the same colored slots so it runs in dual channel!
  11. trati629
    13 Jun 2005
    NO! I forgot to dry my case before I took the photos so there is a wet patch :duh:
  12. trati629
    13 Jun 2005
    Re: Dual Channel Memory
    That is what i thorght but when i was reading the user guide for the mobo
    I saw this. (can you see how confussing it is) :confused:
  13. Jokkocze
    Jokkocze What's a Dremel?
    16 Dec 2004
    Same color for dual channel ;)
    That looks odd tho.. did they do something wrong with the manual for that rev or something?
  14. trati629
    13 Jun 2005
    Thank you I will change the memory over tonight as well as putting some photoes of what arrived in the post this morning and also some Tensol 70.
  15. Unicorn
    25 Jul 2006
    Very nice mate, good luck with the mod. The black interior of the p160 looks badass IMO, very nice indeed. Keep up the work on that front panel, look forward to seeing what it looks like finished!
