Case Mod - In Progress Project : Panda (Antec 300)-paused for a while
Discussion in 'Project Logs' started by k0rben, 24 Jul 2010.
  1. k0rben
    k0rben I use my dremel as a toothbrush
    22 Jul 2010
    Uhm, i'm not sure if i understand what do you mean - 'But will you be able to see the blue on the mobo?' Well, you meant a windowed sidepanel or something like that? I was thinking of applying a plain white sticker on the blue part of the mobo heatsink - here
    and also
    and also - thanks and happy new year!
  2. KidMod-Southpaw
    28 Sep 2010
    Sounds good mate, but how did you make the stickers on the fans? Just curious.
  3. k0rben
    22 Jul 2010
    Oh sry i forgot to tell you my bad :eek:
    i bought an adhesive paper (sticky from one side and regular white paper on the other side) but i picked up the one with the pre-outlined 4 centimeter circles (just the right size for the fan sticker), then just a few minutes with logo+print. And i bought it at Canon - copy/print/office, you should find that too somewhere near you. hope it helps.
  4. KidMod-Southpaw
    28 Sep 2010
    Cheers mate!
  5. KidMod-Southpaw
    28 Sep 2010
    BTW, the chipset heatsink on your board... I don't know if it would be possible as you'll have to get exactly the right paint, but as all the lines come out on the heatsink, what about painting the grey lines black and the blue lines white?
    It would be a challenge... But...:dremel:
  6. BBrown
    BBrown What's a Dremel?
    4 Jan 2011
    Yay! Another 300.
    When you painted it, did you separate all the panels? I've been looking at mine and wondering if it's even a good idea. The I/O shiled has those weird holes that looked crimped onto the rear panel and I fear I shouldn't mess with them, thoughts?
  7. k0rben
    22 Jul 2010
    Thanks for the idea kidmod, the black could be nice on that hs.
    Bbrown, i dismantled only the top here you can see that
    http://a.imageshack.us/img72/6757/image0229pd.jpg
    the the back I/O shield could be easily taken out, altough i'm not entirely sure what do you mean by those crimped holes.
  8. BBrown
    4 Jan 2011
    If you look at the rear of the case it's got two pieces: the rear panel covering the entire back and the I/O assembly (with the PCI slots and I/O opening). I was curious if you had separated the two pieces because there are no rivets connecting the two but they are two pieces. It's those holes that go from the rear panel and grab into matching holes on the I/O assembly.
    Since you hadn't, I'll just leave it and no toy with it.
  9. k0rben
    22 Jul 2010
  10. KidMod-Southpaw
    28 Sep 2010
    Epic thread revival :lol:
    Any updates?
  11. stefan442
    stefan442 Minimodder
    14 Mar 2011
    I have an antec 300... would love to see this get finished for some ideas for mine :D
  12. KidMod-Southpaw
    28 Sep 2010
    Any updates?
  13. k0rben
    22 Jul 2010
    I apologize to everyone wathing this, i had everything from school exams, health issues to massive lazyness :D, but major thing was moving to a new place. I can surely tell you that there aren't gonna be updates for a week or two (have to clean the attic btw)
    anyway, thanks for watching :thumb:
  14. T345
    T345 What's a Dremel?
    25 Jul 2012
    More, this is great inspiration for the mod I'm about to do (weeks :))
