Case Mod - In Progress Project Panzerbox Mod: Tribute to Wolfenstein
Discussion in 'Project Logs' started by CustomPCMAX, 2 Apr 2009.
  1. alecamused
    alecamused Minimodder
    22 Apr 2008
    bullethole-icing for cheesecake-case. awesome :thumb:
  2. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Glad you liked them!
    I heard back from James at PsykoAudio, he suggested turning off the cmss settings in the X-fi software, and turn on EAX. I will check into these setting later today.
  3. mnpctech
    21 Apr 2003
    I am resuscitating this log with a new update. The project was put on the back burner while Nate and I were occupied with other obligations. I've ditched painting the 15" LCD until I can afford something bigger. I'm also swapping out the Razer Lycosa KB to the Logitech G15 KB. I dismantled it yesterday so it can be painted with WWII German Camo, similar to the Panzerbox bezel.
    You must remove all of the Black screws on the back of the G15 KB.
    Gently push open the the Black tab, to pull out the ribbon wire connection.
    Once inside the KB, 19 Silver screws that must be removed.
    After the 19 screws are removed, you must gently pry open the Grey plastic tabs that hold on the Grey trim piece.
    The KB trim piece will be painted WWII German Camo.
    The Logitech badge pops off with ease. It would be cool to mill a new badge from aluminum, maybe the German cross?
    The G15 lens should remove easier by applying pressure from the inside out with a finger.
    I used a model knife to peel off the right side indicator lens
    4x Silver screens fasten on the LCD bezel to the KB.
    G15 LCD bezel buttons removed. The frame of the window will be painted.
  4. Bad_cancer
    Bad_cancer Mauritius? 2nd speck east of africa
    7 Apr 2009
    It lives!!! :clap:
    Great to see this back on track.
    Did you ever get to play Wolfenstein on it?
  5. Draksis
    Draksis What's a Dremel?
    21 Oct 2009
    Sure the KB will come out sweet. can't wait to check it out
  6. mnpctech
    21 Apr 2003
    Yes BC, and it plays very nice :thumb:
    It was really nice of Razer to sponsor the build, but after a few months of usage, I'm not a fan of their light weight plastic construction. I fear they would shatter if they ever dropped off my work shop counter. So I'm swapping out both the Razer Lycosa KB to the Logitech G15 KB. The Razer Mamba Mouse to the G7.
    Boddaker likes this.
  7. mnpctech
    21 Apr 2003
    Updating the rear 120mm exhaust fan with the new Overkill "Sniper" grill, I have Silver version, but you can get Black anodized
    Overkill Grills from Performance-PCs
    The NZXT Panzerbox wide chassis is ideal canidate for the Overkill grill. Most cases may require major modification to your chassis and side panel to clear 5.5" wide grill if mounted over the rear exhaust.
    I use SEM brand Self Etching primer to paint the bare aluminum grill Matte Black. This paint is made for bare metal surfaces. You need to wear a filtered respirator mask and apply in well ventilated room. It's very TOXIC when it's airborne.
    The billet Targeted grill looks cool, but a bit flat looking in comparison :D
    POW! what a difference.
  8. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Okay, this might be a bit dangerous, but I'll do it anyway:
    I don't really like that.
    Don't hurt me! :eeek:
    To me it looks like it was just slapped on, sorry. One of the extremely few things I don't like about your builds, Bill.
  9. stonedsurd
    11 Mar 2009
    I have to agree with perplekks45.
    The grill itse;f is a masterpiece of aluminum pr0n, but it just looks out of place there.
  10. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    I see how it looks better, but having it match up with the lines on the case would make it look even better. I semi agree with above.
  11. sentek
    sentek What's a Dremel?
    5 Jul 2009
    from the pics there something doesnt look quite right about it, in my opinion..
    dont get my wrong, it still looks nice.
    perhaps a pic from further back would show it in a different light, kinda give an overall view of the grill with the rest of the case if you know what i mean.
  12. Bad_cancer
    7 Apr 2009
    ^what he said. i have mixed feelings about this grill. It looks kind of odd.
    It looks like something the army would use i agree, but it kind of looks a bit off too...
    But then again, we should never doubt bill because 'epicness' is his third name (because 'overkill' is the second....ill get my coat :worried:)
  13. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    The inner chamfers on the crosshair are too big and make it look like a plastic toy. Especially when painted in black. I don't mind the overall shape of it.
    Another aspect that makes it pop out too much is that the grill hangs over the motherboard connector plate. Shift the fan 10mm to the right and it should fit better.
  14. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    QFT, it's too important a piece and statement to relegate to the back of the case; it just looks a bit out of place. Still - I assume this case advertises MNPCtech's products, so getting it on the case is probably a priority.
  15. mnpctech
    21 Apr 2003
    It is a bit of an "Overkill" isn't it... sorry, I just had too.
    I completely see your point tho, Thank you :thumb:
  16. Darkraven
    Darkraven What's a Dremel?
    23 Dec 2006
    Sharp eyed bunch around here, wouldn't be Bit-tech without them tho. Hope it stays that way.
    I like the depth of the new one, cuts down just a bit on the contrast of the back of the fan shape to the crosshair pattern.
    I know it's a lot of work for little gain maybe, but if the ears were cut smaller, like 5/16" off each side then maybe it would not be an overstatement as mentioned and then would not overhang the plate it's mounted on, just saying.
    Maybe a few minutes with some fine steelwool to flatten the black a hair more would get rid of the plastic look that was also mentioned.
  17. mnpctech
    21 Apr 2003
    Agree, the legs or "ears" could be refined and I'm guilty for using my own off the shelf bolt-on part :worried: :D
  18. DeadP1xels
    30 Nov 2009
    I like it! bit pricey shipping to uk though would look perfect either side of my mod :O very industrial :rock:
  19. mnpctech
    21 Apr 2003
    Are you looking at our Cart shipping rates? Those are UPS for US only, drop me a PM :thumb:
  20. DeadP1xels
    30 Nov 2009
    I emailed you a while back about a few bits but came something around $25 shipping but the items where pricey (because of the quality offcourse) i think it was your case feet and i could'nt really justify paying £20+ for case feet (with shipping) so im going to wait till i can buy a few things that i really really think would work so it seems more worth my while
    really diggin the grills though :rock:
