Case Mod - In Progress Project Panzerbox Mod: Tribute to Wolfenstein
Discussion in 'Project Logs' started by CustomPCMAX, 2 Apr 2009.
  1. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Thank you!
  2. Volund
    Volund Am I supposed to care?
    16 Sep 2008
    gratz on the nomination bill.
    Any info on temps for the graphics cards due to the location of the power supply?
  3. CustomPCMAX
    CustomPCMAX Computer Geek
    2 Apr 2009
    That is something we will analyze when we get to the installation portion of this. But, I think it is safe to say there is a possibility that it will affect the GPU some. Fortunately, the case has great airflow in general, so it may not be that bad.
  4. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Congratulations on getting my vote. :thumb: :D
  5. mnpctech
    21 Apr 2003
    Thanks for the votes everybody :thumb:
    Stay Tuned, this project has many more cool updates coming soon! :D
  6. Volund
    16 Sep 2008
    k, looking forward to it, I wasn't sure if you did a test install before the modding began.
  7. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    I really doubt there's going to be a major difference in performance with the GPUs and the PSU oriented like that. The case is really friendly to airflow just by looking at the layout and specs, so I don't see there being any issues.
    Kick some aysh, Bill!
  8. The boy 4rm oz
    10 Apr 2008
    Congratz on the nomination Bill, really is amazing work.
  9. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    Love the theme. Nice project and good ideas.
  10. B4TM4N
    B4TM4N Ninja
    11 Aug 2008
    This is a very nice mod indeed!
    Congratulation on the Mod of the Month Nomination, you must feel proud ;)
    Needs MOAR updates!
  11. perplekks45
    9 May 2004
    Naw, he's used to that by now. :D
  12. mnpctech
    21 Apr 2003
    More updates on the way. We're painting the machined aluminum bullet thumbscrews to look more authentic.
    The surface is first prepped, using red scotch brite pad to scuff the bare aluminum
    Is that a "cribbage board" for thumbscrews?, drilling holes in a piece of wood, works great for holding thumbscrews for paint. The threads were taped off.
    For maximum paint adhesion, we use SEM brand self etching primer for the base coat
    A couple coats of grey self etching primer
  13. E.E.L. Ambiense
    26 Jul 2007
    Oh, sweet. That's cool, Bill. I take it you're going for a weathered bullet look?
    I do something similar with screws being painted with the 'peg board holes'; it's cool seeing others doing it!
  14. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    yeah they are cool thumbscrews... nice painting so far. and a great mod
  15. mnpctech
    21 Apr 2003
    Yes, and painting these is a must, it's all about those small details we all crave :D
    Brad prefers to tape the bullet thumbscrews to paint stick
    Paint entire bullet first copper color first, mask off the tip after cured, then paint the shell brass color.
  16. stonedsurd
    11 Mar 2009
    O mai. naice! :thumb:
  17. CustomPCMAX
    2 Apr 2009
  18. The boy 4rm oz
    10 Apr 2008
    Fantastic idea with painting the thumbscrews, they will go perfectly.
  19. stonedsurd
    11 Mar 2009
    LOL, even the Fatal1ty logo resembles the Wolfenstein theme! :clap:
  20. mnpctech
    21 Apr 2003
    I'll have the bullets posted today, I'll also have to get that Titanium from you sometime soon Nate.
