Project "Parabox"
Discussion in 'Project Logs' started by Raygen, 19 May 2005.
  1. Raygen
    Raygen What's a Dremel?
    19 May 2005
    Project Parabox
    Started: End of 2003.
    http://photobucket.com/albums/v413/koda/Modding/Parabox/
    Unfortunately I didn't have my digicam back when I started the mod so no pics until I started working on the lcd.
    VFD:
    The VFD was originally purchased from america from a small electronics shop (originally came from old medical equipment), pretty much bare of everything except the technical docs. I wired it up to my com port and then attempted to write some software for it, Ifailed. I found that the company had held a small comp for software designers to write code to drive the unit but since only around 20 were ever sold it was a small comp. I eventually got it working perfectly, later which I adopted the program LCDC to drive it.
    Its mounted in my cases side window by 4 screws.
    LCD:
    I ontained a thrustmaster psone lcd from cashies after seeing cases such as 10ghz blackmagic with envious eyes. And it helps for leeching at lans. It runs off a PCI Matrox G200 vid card with a blistering 84.5mhz!!
    I went about pulling the LCD apart and splicing a vga cable into its input
    Success! After I set the timings for it in powerstrip it can run at 720x568 or 640x480.
    On the test mount it fit perfectly.
    LCD Eye Candy:
    Bay Hider:
    Built out of the back of an old optical drive, its purpose is to hide all the wires from the lcd.
    Stealthed blacklit optical drive:
    This part of the project was a spur of the moment genious idea, it involved glossing the stealth drive perspex plus lighting it up with a neat-o pattern. I googled for an
    awesome looking pattern and found one that looked great, only problem was that only half of it looked great, so I photoshopped it to by symmectrical and went about completing this.
    http://img.photobucket.com/albums/v413/koda/Modding/Parabox/Stealthed Drive/IMGP2053.jpg
    ===================== <-mount for the optic drive.
    ============= <- back light grabber over pattern. The masking tape goes between this and the mount ^^^^
    ============================ <- front perspex with pattern
    I put a small gap hider over the space between the pattern and the lcd where the led light came though.
    Case Spray:
    Cheap can spray, bad idea.... It looks good aslong as you dont look to close =P Looks quite nice when the ccfls are on though, kind of like matt silver.
    I seem to be missing the pics of the actual applying of the silver, so you ony get primer shots.
    A close up, it seems to scratch really really easily =(
    Might need to touch up that little bit.
    Perspex Spray:
    As suggested by Michael999, to help combat dust behind perspex pannels on a black background (which looks terrible) I should try spraying the back of the front perspex. I
    ended up spraying it with gloss acrylic black, the reflectiveness of the front spex was increased 100x, sweet. I lost my blue led light effect though =`(.
    I tried filling the holes with flour to stop the paint to them, but that just made a horrible mess. I settled with sugar in the holes, worked perfectly.
    Finished Product:
    Well, I think that about coveres it all, or as much as I can remember.
  2. -SilentNight-
    -SilentNight- Hardcore pro gamer
    24 Jan 2004
    can u take more images from that lcd
  3. nitro.vo
    nitro.vo What's a Dremel?
    6 May 2005
    Thats the **** :D
    Love it man, as i've told you many times :)
  4. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    yes! agreed and welcomes another ozzy modder to bittch :rock:
  5. BrokeEnthusiast
    BrokeEnthusiast What's a Dremel?
    28 Mar 2005
    That is tight. I wish I knew how to wire up LCD's
  6. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    ive got a 15'' laptop lcd here, how the hell do i wire it up (to s-video/VGA?)
    Thanks! :) nice mod btw!!
  7. Go4t
    Go4t i
    13 Dec 2003
  8. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    Great job from the land of Oz. ;)
    Your cat is awesome, I want you to know that. If you don't mind, I think I'll probably copy that image of it looking (rather perplexed) at your LCD. ;)
  9. Techx
    Techx What's a Dremel?
    9 May 2004
    haha yea thats a cool pic.. especially since the text on the lcd is asian :p
  10. Raygen
    19 May 2005
    ye, my cats name is caramel. It was probably thinking, ok whats going on here =)
  11. webbyman
    webbyman Hax.
    7 Oct 2004
    awww thats the cutest picture i have seen in ages :D
    nice lcds :dremel:
  12. BBurger
    BBurger What's a Dremel?
    7 Apr 2005
    So, what is it with cats & modders? Sometimes it seems like at least a third of the modding projects posted here have a cat involved - or several cats!
    Great project, turned out really nice.
  13. invader crack
    invader crack What's a Dremel?
    18 Jul 2004
    hey it looks like ur front lcd temp is in celsius i have an Xdreamer2 with the exact temp lcd i was just wondering if its possible to change it to celsius as im in canada and fahrenheit makes less sense to me..
    and by the way excellent mod ive been wanting a psone lcd forever now :D
  14. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    THere is an artical somewhere that states Cats are considered a computer geeks main accessory. Scientificly proven. GO figure... I'll hunt it down, my roommate has it somewhere.
  15. BBurger
    7 Apr 2005
    I'd love to see that! I'm currently catless - I move too much - but always had cats growing up.
    </thread hijack>
    The kitten peering into the box reminded me of the Infinite Cat Project's pictures.
  16. taliban_raider
    taliban_raider Just some guy; you know
    28 Feb 2003
    Nice to see another Australian modder on the forums, an Atomican none the less :rock:
    Nice case you got there, and as everyone has said that is quite a cool pic of the cat looking at the LCD.
  17. sargeras0000
    sargeras0000 What's a Dremel?
    25 Jul 2007
    The article is called The Jargon File.
    Its about hacking and things.
    Here's a Link:
    http://www.catb.org/jargon/html/index.html
    The Information in in Appendix B, A Portrait of J. Random Hacker, in the miscellaneous section, linked directly here:
    http://www.catb.org/jargon/html/miscellaneous.html
    Hope this helps, and, i am a cat person.:)
  18. Teyber
    Teyber ******
    18 Mar 2007
    nice work! i love the cats...
  19. mattthegamer463
    26 Nov 2004
    Good mod and all, but its 2 years old! Stop digging up old threads just to beat them with a shovel.
    sweet mod, nice cat, etc..
  20. ComputerKing
    8 Sep 2006
    WOWOWOWOOWOWOWOWWOWowowowooww
    dude you have kickass kickaass case dammmmmmm I love it I wish I can do some thing like it :(
    well done and great job and take care
