Scratch Build – In Progress Project: Paris Hilton
Discussion in 'Project Logs' started by Samaya, 2 Jan 2008.
  1. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    nice name, good looking grill too
  2. Jipa
    5 Feb 2004
    Good work with the grill.. Less so with the name :D Ok it made me lol, but I really wouldn't like to say "I built Paris Hilton". My choice would've been either BIC (bulimia in camoflage) or AEMWDLI (anorexia even my wife doesn't like it). Keep up the good work!
  3. Pfaffen
    Pfaffen What's a Dremel?
    18 Mar 2007
    Nice start. I really like the fan grill. Well done. BTW, what bit did you use on the dremel and what speed. I find the spiral bit the best and at about an 6 or 8, anything faster and the plexi begins to melt.
    Remember to allow for the PSU. I like the thin design.
  4. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    The grill is looking quite nice so far. However, isn't naming your project Paris Hilton rather asking for a computer that doesn't use all the cpu power and goes down all the time?
  5. Samaya
    Samaya Lion Country
    2 Jan 2008
    I didn't name it Paris Hilton.
  6. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    It will go down alot & it will use all the cpu power - but thats just to be able to do simple things. Doing advanced things would mean having dual minimum or better yet quad cores, so in other words, the pc will be vista ready.
  7. Samaya
    Samaya Lion Country
    2 Jan 2008
    Ok from Wonka's edit I have decided to keep the new Name. It suits this project very well. P4 2.8GHz Northwood core. Can't do very much but it can still do the basics.
    If it has quad cores then I can't name it Paris Hilton anymore. LOL
  8. Sparrowhawk
    Sparrowhawk Wetsander
    14 Feb 2004
    Problem with the new name, though, is it's not a carputer. It can't flash it's naughty inner bits (ooh, erm) to waiting paparazzi when you unmount it and bring it inside. :wallbash:
  9. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    :hehe: :lol: (Note to self: never drink carbonated drinks while browsing the forums :worried:)
    Seconded
  10. Cheapskate
    13 May 2007
    @Tyinsar- Putting those two quotes together changes the meaning perfectly.:hehe:
  11. shomann
    shomann Minimodder
    5 Sep 2003
    It's funny, when I was browsing the forum I saw the new name and thought - "what, 2 computers based off of a skinny-ass theme?"
    At least the new name fits the concept.
    Alternate names (although I think the new name would be a long remembered one here on bit-tech)
    The Flockhart
    The Lohan
    The Olsen
    The Hepburn (would be a bit classier, but she was a tiny thing, I am talking Audrey)
    The T.Rain (watch some pron and figure out who I am talking about)
  12. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    LOL the new name cracked me up when i saw it.
  13. Frenkie
    Frenkie Lets mod the world!
    3 Jul 2006
    How about; "Overrated-skinny-no-tits-****s-everything-in-sight-and-still-gets-no-millions-from-grandpa".... or is it s bit too long ? ;)
  14. Cheapskate
    13 May 2007
    -And slightly bitter sounding.:hehe:
    How about:
    "Binge and Purgebot 2.0"
    "Streamlined To Death"
    "Jenny Craig Programmed"
    "I Can see your Barebones"
    "Slinky"
  15. Cheapskate
    13 May 2007
    I forgot one:
    "Your 'Pooter is Showing"
  16. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    I Second "The Lohan"
  17. mvagusta
    24 Dec 2006
    That's a full page of discussion about the name of a project - a bit-tech first possibly? You gotta catch the thread drift samaya, before you know it, there'll be another page on stuff like: moral use of money, eating properly, sex, which skinny celebrity is the hottest/thinest/sluttiest etc
    I think the only change this log has is regular updates actually, i can see the thread dirfting again between updates if left waiting too long :hehe:
  18. Teyber
    Teyber ******
    18 Mar 2007
    its official. The BNOM-best name of the month
  19. Samaya
    Samaya Lion Country
    2 Jan 2008
    I didn't expect this many responses to the naming of the case. Updates will only unfortunately occur weekly only because I can only mod over weekends :miffed:
    Anyway so before I get slapped for having too few updates here is one. I worked on the one side panel yesterday. It took forever to get the edges at an angle but was worth it. I also bent the plexi panel to fit the back panel.
    The edges all have this angled edge
    Fitted and fixed with some pretty button head screws
    Not much of an update but this took very long to get right. I still have to polish it more and then do the front panel.
  20. Samaya
    Samaya Lion Country
    2 Jan 2008
    I had a problem with my orbital sander a while back and had to have it replaced under guarantee. This took 4 weeks to manage, BW service is not so good when it comes to things like this. Anyway I had some time to mod yesterday and did just that.
    I cut the main side panel for this case, I polished the clear plexi and then fitted everything together.
    Before polishing
    Half way there
    And done.
    I did the polishing with my sander using only 1200 grit sanding paper. Obviously 400 as well because I had to get the fine scrathes out but the 1200 was used to finish it off.
    After I polished these edges I fixed the clear front to the side red panel.
    Then onto the main panel, the one that keeps everything in its place.
    After a lot of measurements and filing away excess it came out looking like this
    Front
    Back
    I still have to polish the edges of the black perspex, cut the hole for the CPU fan, add the on/off, reset and DVD drive buttons, cut out the MoBo connectors and then do some more small detailing.
    I hope you enjoy this little advancement
