Project: Phantom Black, 11 January 2007; Two updates, 16.1.2007
Discussion in 'Project Logs' started by Darkened, 11 Jan 2007.
  1. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Nice lighting-effect. Looks as though the case is "floating"..
    BUt, if you polish the edge of your acrylic the light will (should) become more uniform.
    You know the drill. Same as polishing Alu:
    Lots of sanding (dry then wet) then polishing. Novus-polish is very good (aka heavy then fine scratch remover).
    Good-stuff, Dark.. You are off to a excellent start..
  2. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    I absolutely LOVE that dark! I have one question, is it still gonna be an HTPC?
  3. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    looking good, I agree with Modsquad (also on the Novus-polish)
  4. Darkened
    Darkened New Member
    28 Feb 2004
    Lot's of comments, it's like christmas :hehe:
    Thanks to all, as I always say, input is much appreciated.
    @elliod
    Yes, there's going to be at least 2 switches to control the lighting.
    @Javerh
    As always, that's going to be a "surprise", darkened likes to keep people in the dark :hehe:
    @modsquad and jokkos
    As I said earlier, the bottom plate is far from being ready, but for the polishing issue, wouldn't it diffuse the light better if the edges were sanded say with 600grit?
    And also, this Novus must be good stuff, but I've learned to cut some corners when polishing acrylic, same as I do with alu, no wetsanding for me anymore :thumb:
    The way I polish acrylic (if not flame polishing) is that I sand the edges down with 240grit dry paper so that they are smooth (no cutting marks etc.) and then attach the cloth wheel to the drillpress and use the Wolfcraft polishing compound (blue bar of soap :D) with say 1800 rpm. Believe me, works wonders and fast + it doesn't scratch the surface of the acrylic. Try it, you might be surprised.
    @Mother-Gooser
    Yes, it will be it's destiny...who said that :worried:
    I have a couple of nights work ahead, so no updates for a while (unless I can get my arse out of bed in time :hehe:).
    Janne signing off...
  5. JazX101
    JazX101 New Member
    27 Jun 2004
    underlit case, uber-class
    Jaz_knos
  6. Snafu-X-
    Snafu-X- New Member
    27 May 2005
    A frosted edge will give a more diffuse light than a clear edge. Nice start to the project, looking forward to more.
  7. chase
    chase New Member
    11 May 2006
    That's looking mighty fine Dark ;)
  8. Evenge
    Evenge Member
    16 Sep 2006
    I like that light effect! :thumb:
    Keep up the good work!
  9. WiK1d
    WiK1d New Member
    16 May 2006
    I love this. This is awesome. Can't wait to see what the finished case will look like. You guys are seriously very very talented!!
  10. rowin4kicks
    rowin4kicks a man walked into a bar ...
    5 Feb 2006
    nice glad to see you keeping it simple with the colours (i love white leds, just soemthing about them)!
    keep up the good work
  11. Darkened
    Darkened New Member
    28 Feb 2004
    Thanks for your comments guys, I'll try to bring you the next update as soon as possible and also on Orange Monster.
    Janne
  12. calib3r
    calib3r New Member
    11 Jul 2006
    One word, subscribed.
  13. Heero195
    Heero195 New Member
    12 Jun 2006
    The only I have to say other then the project looks amazing is, isn't that going to be a bit bright when sitting around watching movies ? Will there be a dimmer switch added ?
  14. calib3r
    calib3r New Member
    11 Jul 2006
    Maybe he watches movies with the room lights on, some people do that.
  15. P.P InDaHouse
    P.P InDaHouse New Member
    30 Jan 2007
    any update? :thumb:
  16. Darkened
    Darkened New Member
    28 Feb 2004
    Unfortunately the same thing applies here than it does in the OM thread, I'm swamped with schoolwork at the moment, but I'll try to put up an update ASAP here as well.
    @Heero195 and calib3r
    There will be on/off switches...
    Janne
  17. karbonKid
    karbonKid Member
    5 Jul 2006
    That's 3 words :p !!! only joking lol,
    Nice work, darkened
    i am subscribed too, can't wait to see some updates!
  18. Zds
    Zds New Member
    3 Nov 2005
    Very nice start indeed. Subscribed!
  19. calib3r
    calib3r New Member
    11 Jul 2006
    I want updates!
  20. HaoKi
    HaoKi Lleno de anguilas!
    10 Oct 2003
    Life still interfering with the project? :hehe:
    Keep up the great work. Great seeing some finnish talent here...;)
