Project: Phenom Rebirth Updated [01-06-04] (Pics Fixed)
Discussion in 'Project Logs' started by Taker, 21 Dec 2003.
  1. Taker
    Taker What's a Dremel?
    21 Dec 2003
    I have been working on this for some time now. It is in its early stages, so its going to get cleaned up. Here are some pics of my progress so far.
    http://www.casemod.com/showgallery.php?ppuser=1307
    Specs.
    Pentium 4 2.8GHZ
    Abit IC7 Max2
    OCZ 517 DDR ram
    ATI 9800 Pro 128 mb Overclocked
    Creative sound card
    + watercooling for Processor and Graphics card
    New pictures soon of radiator, control panel, and pump
  2. 3vil-Grin
    3vil-Grin What's a Dremel?
    25 Jun 2003
    Welcome to the forums!!!
    So what do you have plan in the near future for this case?!
    Also what is it made out of??
    :D
  3. Taker
    21 Dec 2003
    I am making a control panel for this that has fan controlers, a LCD screen and temperature sensors. There will be a water cooling system hooked up in there. There will also be a tower full of fans in the back of the case. I keep adding stuff as I go on int he project.
    The control panel will be done sometime this week.
    The case is made of plexi glass and the black stuff is vent filters that you use in heaters. I just sprayed it black. Im hoping that the vent filters will allow better air flow through the case and block the dust from coming in. I also did it so that when the hot air raises it can escape.
  4. Wicked Li'l Bender
    Wicked Li'l Bender What's a Dremel?
    9 Nov 2003
    also doubles as an air purifier!
    Like what you have so far! can't wait to see what you do with it next!! I will keep my eye on this one!
  5. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    looks nice so far. Keep it up man.
  6. 3vil-Grin
    25 Jun 2003
    wow that sounds like a lot stuff...great idea though.
    *waits for more patiently
    :D
  7. RR5
    RR5 What's a Dremel?
    7 Dec 2003
    Rock on, california mod. I'll keep my eye on this.
    I like what you got planned so far.
  8. Taker
    21 Dec 2003
    Pics
    Pictures moved to first post.
  9. NexteR
    NexteR What's a Dremel?
    6 Nov 2003
    looks cool :dremel:
  10. macroman
    macroman The One
    3 Sep 2001
    I like the look of this although I can't be too sure of the shape from your pics it looks quite curvy?
    "Taker" - "Phenom" any WWE conitations there? ;)
  11. djengiz
    djengiz Pointless.
    16 Aug 2002
    Links dont seem to work
  12. 3vil-Grin
    25 Jun 2003
    NOOOOO I cant see...Stupid connection...Hold on its not my connection....mmmm...must be the link...Whew!!! close call....
    No pics no links no nothing.... :worried:
  13. Fraggster
    Fraggster What's a Dremel?
    30 Dec 2003
    no pics :waah:
  14. KRASH
    KRASH What's a Dremel?
    27 Oct 2003
    No pics ! I had this prob! read sticky in project logs.
  15. Taker
    21 Dec 2003
    Update 2
    Well it has been a busy week. Been working a lot and helping a friend build his pc, but I managed to get some stuff finished. And yes this is related to the UnderTaker from the WWE.
    Here is my radiator. It is sprayed chrome on the outside and is copper on the inside.
    I finished my tower of fans.
    Here is my pump. Its sprayed chrome and I am also looking for some chrome fittings.
    Here is a teaser for the control panel.
    That’s it for now; I plan on finishing the control panel soon. If you have any ideas or suggestions I am all ears.
  16. RR5
    7 Dec 2003
    Are you going to use any tint on the panels of the case at all?
  17. Taker
    21 Dec 2003
    Maybe ill see how everything goes together.
  18. RR5
    7 Dec 2003
    Do you have any overall shots so we can see the progress made?
  19. Taker
    21 Dec 2003
    Ya im going to have some pictures of the overall progress wonce the control panel is finished. Wonce its finished you will get a good idea of what it will look like.
  20. Taker
    21 Dec 2003
    Water Blocks
    Well, I have been sick with the Flu and unable to work on my pc that much. I recently ordered some water blocks and I thought I share them with you.
    Here are the three water blocks I will be using in my system. They are the polar flo blocks and they are chromed. They cost an extra 20 bucks to be chromed, but I think it was worth it.
    Here is the Cpu block. It already comes with a nice finish.
    Here is the chipset water block. It has an alright finish to it.
    Here is the Graphics card water block. I plan on getting more water blocks for cooling my ram on the ATI 9800 XT 256 mb.
    Here are the case badge I made on my computer. I have a really good spot to put them on my case.
    Until Next Time
