Project: PHOENIX (24.09.2005)
Discussion in 'Project Logs' started by RadeX, 25 Aug 2005.
  1. RadeX
    RadeX What's a Dremel?
    1 Sep 2004
    hi all
    this is my another project
    this time it will be designed much better then the last one ;)
    and here is the victim:
    here is the project of the sides
    and photos from first cutings
    isn't this front panel beautiful? :D
    greetings 4 all moders :rock:
  2. HAXOR
    HAXOR Minimodder
    14 Oct 2003
    Wow. that's a case with a lot of modding potential! I hope you use every last bit of it. :)
    It's looking good I think. Are you going to do a plexi front panel with etches, or will it have something to do with bondo?
  3. Bluefan
    Bluefan test 123
    25 Feb 2005
    It really got potential
  4. RadeX
    1 Sep 2004
    bondo? what's this? :]
    the front panel will be from dark arcyclic, window too. and under the tatoos will be dark arcyclic too
  5. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    Bondo= A kind of car (boats, and others) body filler :)
  6. RadeX
    1 Sep 2004
    then yes ;] I will use it too
  7. simosaurus
    simosaurus What's a Dremel?
    12 Jun 2005
    very nice tribal shapes u got on there, good luck
  8. RadeX
    1 Sep 2004
    two tribals cuted :)
  9. HAXOR
    HAXOR Minimodder
    14 Oct 2003
    lookin great! How do you like that flex shaft? When I tried to use mine the other day ago it didn't seem to work right. =\
    Maybe I need to greese it again. It kept catching on the edge of the metal then grinding to a stop. Perhaps the shaft wasn't all the way in the chuck....
  10. RadeX
    1 Sep 2004
  11. HAXOR
    HAXOR Minimodder
    14 Oct 2003
    Yeah, looks like the same design and probably the same construction. You haven't had any problems with it slowing down or jaming up though?
  12. RadeX
    1 Sep 2004
    slowing down & jaming - yes, sometimes :/ when it stucks in the metal, and sometimes kole dremel started to spin a little :lol: but never mind, today some update ;]
  13. RadeX
    1 Sep 2004
    2 photos from cuting the second side
    rest tomorrow :]
  14. RadeX
    1 Sep 2004
    second side cuted :) it's a little bit dirty especially near the cut lines but I won't clean it now cause I have to grind the tribal
  15. Jipa
    5 Feb 2004
    Nice tribals, I really don't have skills neither nerves to do cuts like that..
    Keep it up.
  16. webbyman
    webbyman Hax.
    7 Oct 2004
    looks like this is going to be worth watching :) keep it up ;)
  17. The Lost Monk
    The Lost Monk What's a Dremel?
    16 Sep 2004
    looking really good keep it up
  18. mondriaan
    mondriaan What's a Dremel?
    20 Aug 2004
    Looking good that :dremel: work you've done so far.
    :thumb: :thumb: :thumb:
  19. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    Nice tribal designs - you do them yourself?
  20. RadeX
    1 Sep 2004
    I found them somewhere and remake ;]
