My First Case Mod ! : The Specs first : THE SPECS CHANGED! Check out my Sig! Loads of Fans ( I will talk about them later in this thread ) Lunar Server Tower ( You probably havent heard the name before, its a cheap *** company ) All the pics are hosted on my pc, so they might be down for some time or even load up very slowly... Please excuse my English, its not my native language.
Currently hosting the pics @ Photobucket. Anywhere else where i can host them ? As Photobucket is giving me only 2500 / megs per month!
Before i go on i must enlighten you about the fact that me and my friend both got the exact same casing and both had decided to mod it. Moving onwards, After i got this casing what i needed was a PLAN! On the Side : 2 x 92MMs Over the CPU,NB,RAM 2 x 92MMs Over the GPU. I decided to cut the side panels and install Arcylic Windows on both the Sides. For the other fans I decided 1 x 80MM As Intake in the front, for the HD. 1 x 120MM as Intake at the bottom. 2 x 120MM at the top for Exhaust. 2 x 80MM at the top rear for exhaust. 1 x 60MM at the rear. 1 x 92MM PCI Exhaust.
I then got some Plexi Glass from a local store and then made some holes. Cutted the side panels and made holes for the side panels to fit onto it. Screws Installed Meanwhile the casing ...
It was now time to lighten it up! I used the Thermaltake Cold Cathode the bottom : And a cheap ass neon light which i got from my local stores at the bottom :
I have modded my casing uptill here, Any more suggestions before i start installing the hardware in ? Which of the Side Panels look good ? Should i leave the plexi glass as it is or install the rubber ?
Interesting... I did a case like this almost 2 years ago... First major mod. Case was really loud... you are running 8 fans... tornado is coming. Good work though
Agree Thats damn sweet. I wish I had a case that size. You just can't seem to buy them these days Iv found
