Project Plex...
Discussion in 'Project Logs' started by axelh, 9 Apr 2007.
  1. cr3ativ3
    cr3ativ3 What's a Dremel?
    24 Apr 2007
    going nice so far..
    keep us posted m8!
    Good luck
    regards
  2. axelh
    axelh What's a Dremel?
    17 Dec 2006
    Thanks man!
    I'll be updating when the next package arrives..Hopefully in the beginning of next week...
    Axel
  3. axelh
    17 Dec 2006
    UPDATE 05.05.07
    I received some packages today :clap:
    I thought I'd would start with the mother board tray.
    Drawing the outline.
    Cut out and ready.
    Mounted on the tray.
    So far it looks like this.
    Then the other side.
    The result.
    I'll probably get some work done tomorrow. In the meantime, any comments?
    Axel
  4. axelh
    17 Dec 2006
    UPDATE 06.05.07
    This morning I finished all the parts for the motherboard tray.
    Ready to pop it back together.
    Or not. I only had 3 rivets so I will have to buy some more tomorrow. Here it is half done.
    Axel
  5. Mr-IK
    Mr-IK Minimodder
    12 Mar 2007
    Looks nice :) A few marks in the carbonfibre or just bad angle?
    Anyway, it looks better than i thought it would when you started :)
  6. SlappKnutts
    SlappKnutts What's a Dremel?
    28 Jan 2007
    I'm not personally a big fan of the CF sheeting but will see how it looks in the end product... The rest is looking rather well, especially since everything is twice as tough when using your bed as a workspace! ;-)
  7. axelh
    17 Dec 2006
    Thanks man... There are a few marks at the back of the motherboard tray because of the standoff bolts for the motherboard. It's no big problem as this side won't be seen anyway. In the top right corner at the front there is also some marks but the motherboard will cover it. The rest is perfect :rock:
    Thanks...Hehe...My room isn't very big and the only table is used for homework so the bed is my workspace :dremel:
    Axel
  8. axelh
    17 Dec 2006
    UPDATE 06.05.07
    Because of homework I don't have time to describe the pictures so they will have to do the talking this time.
    Axel
  9. gar
    gar Minimodder
    15 Sep 2004
    I really like the natural weave there. Allot more tasteful then the sheets with black and grey sqaures! Well done! That was a great idea!
  10. nazomcg
    nazomcg Minimodder
    4 Aug 2006
    Lovin the carbon fibre, and as far as i can tell your case is gonna look very light with all the low weight material in it lol.
  11. antipatico
    antipatico What's a Dremel?
    2 May 2007
    Too much carbon in my opinion, but to each his own :p
  12. axelh
    17 Dec 2006
    Thanks guys!
    There will be a lot of uv green acryl that covers some of the carbon fibre so in the end I don't think it will be to much...
    Axel
  13. axelh
    17 Dec 2006
    UPDATE 07.05.07
    I worked all morning to finish the carbon fibre job...
    Update later today...
    Axel
  14. Neji
    Neji What's a Dremel?
    3 Jan 2006
    It's really impressive work you've done with the carbon fibre. That kind of dedication is inspiring! But it's late so I'll just cruise the forum.
  15. gar
    gar Minimodder
    15 Sep 2004
    You keep workin away there! First class! It's gonna look very cool!
  16. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    ok, its later today, where's the update
    :D j/k man. the carbon looks great, better than most fake carbon.
  17. axelh
    17 Dec 2006
    Thanks a lot guys!
    Update within the hour...
    Axel
  18. axelh
    17 Dec 2006
    UPDATE 07.05.07
    I got some rivets after work and here is the result.
    Next update: C-STRIP!
    Axel
  19. Mr.Anki
    Mr.Anki What's a Dremel?
    10 Feb 2007
    Nice carbon;)
  20. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    Ever heard the phrase , "too much of a good thing can be a bad thing?" The carbon looks really good but I hope you have something else to balance it out with.
