Project: Plexicus iLLuminati !
Discussion in 'Project Logs' started by The_Resetter, 22 Nov 2003.
  1. birdie
    birdie What's a Dremel?
    5 May 2003
    yeah i do remember seeing the torch.
    Yeah now you say that it was only with the chloroform (i remember now). (sorry)
    How does flaming polished acrylic withstand drilling holes in it? or should I leave the flame polishing to absolute last if i decide to do it?
  2. The_Resetter
    The_Resetter I LIKE CAKE!
    6 Oct 2003
    I first made all the holes and stuff, then polished it, so I don’t know if it can withstand but I think so.
    But why polish and then drill if u make scratches u have to polish it again anyway :p so I’d say save it for last.
  3. kiljoi
    kiljoi I *am* a computer king.
    13 Oct 2003
    :read:
  4. The_Resetter
    6 Oct 2003
    I thank U :p ;)
    TBH I dint even knew it was already present :p
  5. Altron
    Altron Minimodder
    12 Dec 2002
    :read:
    Look at post 129 on Page 7.
    :hehe:
  6. Spotpuff
    Spotpuff What's a Dremel?
    16 Feb 2004
    Hands down the sweetest plexi mod I've seen to date.
    Those sanded/polished pieces are like... just wow. Kinda IMac-ish but that's forgiveable :)
    Any tips for sanding/polishing? Or did you do that with the torch too?
    Also, you mentioned cracking. If you heat the plexi will it crack for sure or just when put under pressure or under some other circumstances?
  7. The_Resetter
    6 Oct 2003
    ITS NOT IMACHISCH !!!!!!! :grr: :grr: :grr: :grr: :grr: /me hates mac, :naughty:
    And for the rest of your question i suggest u try and :read:
  8. kiljoi
    13 Oct 2003
    I like it man. Very stylish. But not too complicated. I really like the etching you did.
  9. Spotpuff
    16 Feb 2004
    Mac displays
    The curved plexi w/ the 2 legs... just... looks kinda similar? Kinda? Not as the hdd rack but as the other MB mount you did.
    I did read the thread. I thought most people used novus to polish, not blue flames. The other thread someone linked to basically said don't flame polish, because it will crack plexi if you use solvent.
  10. The_Resetter
    6 Oct 2003
    Yea only if u use a solvent, like chloroform and accetone (or acrylic cement)
  11. alianyn
    alianyn What's a Dremel?
    8 Nov 2003
    you know you are MY plexi guru right?
    thanks for the advice and other suport ;)
    to quote a beer commercial (my faorite ones) - "i don`t know why they say it`s probably the best plexi project in the world, it`s definitely the best plexi project in the world".
    u got the knowledge!
  12. Tidy_Sammy
    Tidy_Sammy What's a Dremel?
    16 Oct 2003
    Brillant case there man, some real nice work with plexi :D
  13. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    looking cool, good job
  14. Rain
    Rain What's a Dremel?
    16 Jun 2002
    Need an update fix :waah:
  15. The_Resetter
    6 Oct 2003
    ??? I think u mean a final post.
    Well, ill post it when I wrote a nice little story over it for a Dutch site :D
