how about a window on the top of the case and a few blowholes but paint the whole case Illuminous Pink then The two bits coming out the front can be tats.
there will be suck hole in top .... blow hole in front ... blow hole in gfx card ... sck hole near cpu .. can anyone do me a schematic fof the best air cooling ....
i say you paint the Y-intake the intieror of it really really shiny then put some dissfused, thats my 2 cents worth
at this point, i didnt say hate. just a dislike that is gently subsiding. it all started... (insert blurry tv effect here) when i did a project log of my crappy little keyboard mod. you said that it wasnt supposed to be in "project logs", so ya... it kinda got planted in my subconscious that i didnt like u. then, your pictures took forever to load. it only caused a snowball effect. Now that you have some pics that r halfway decent and whatnot, im feeling more nice towards u. i really am starting to like this project. you've done a good job, and i congradulate you. hope to see more. God bless.
ok .. another uptate with pics today i bondoed .. again .. but still more bondoing to doo .. more pics later
Very nice. I would recomend sealing off, or filling in the holes at the end of the y-intake so the fans fit nicer.
Multi colored will look great on that case. That Bondo is going to be nasty, trying to get all those holes filled in (the tiny ones on the side - I think from smoothing the Bondo?)
Hehehe... FINISHING COMPOUND IS YOUR FRIEND!!!!!! I learned a ton on bondo and how get it nice and flat. When you are at the point you are sanding with 1000-1500 grit, go get some finishing coupound. Much finer grit, no mixing. You just squeeze a bit out if the tube, and apply. Let dry and *gently* with the 1500 grit, perfect the surface! Keep it going bro!
