Scratch Build – In Progress Project: Prime - Update: May 21st - Yes, really
Discussion in 'Project Logs' started by Sleepstreamer, 1 Nov 2009.
  1. DeadP1xels
    DeadP1xels Music Enthusiast
    30 Nov 2009
    This thing is looking so cool it hurts :p
    this thing is going to look very high tech when its done :O
  2. stonedsurd
    11 Mar 2009
    Sandblasting or bead blasting would look awesome, IMO. Don't paint the lovely aluminum :D
  3. n0va
    n0va Burnin'!
    27 May 2009
    Yeah, seriously sand blasting would be awesome. Gotta keep it real, bro ;)
  4. Sleepstreamer
    Sleepstreamer I modded christmas!
    23 Jul 2006
    Then it's decided :) Not sure what kind of sandblasting I've got access to though, got to make some calls I guess...
  5. Sleepstreamer
    23 Jul 2006
    Had a spare hour today so I decided to spend it grinding the back panel into shape. Next stop will be to make some brackets for it.
  6. The boy 4rm oz
    10 Apr 2008
    This build is coming very well, it looks awesome. I can't wait for more.
  7. Sleepstreamer
    23 Jul 2006
    Sorry about the update-vacuum lately, just haven't had any time to do anything major. I was planning to make one big update once I get the front finished, but since I don't know when that might happen I might aswell show you what I've done so far.
    Making a front bezel for the center of the front.
    Planning to mount it to the case using these brackets, but that's as far as I got.
    I REALLY hope I get some get to finish this off this weekend, hate having a semi-finished project without the time to work on it.
    Hope you like the look of the front :)
  8. Cleveland216
    Cleveland216 Carbon Fiber King
    30 Dec 2007
    Who did your etching for you?? Where do you get etching done at?? I see your in sweden n I'm in the US. The build is coming along very nicely. Congrats on the MOTM
  9. Raiden
    Raiden Portuguese reviewer
    26 Oct 2009
    Damn !!!
    Nice modding , im loving it ..
    Keep it coming..
    Congrats on the Motm
  10. The boy 4rm oz
    10 Apr 2008
    Did you etch that yourself Sleepstreamer? Very nice work.
  11. Sleepstreamer
    23 Jul 2006
    You can do it quite easily yourself with a dremel and an engraving bit, done it several times before. This time I just used the cnc, as I cut out the front with it it wasn't much work doing some engraving aswell.
  12. Evenge
    Evenge Member
    16 Sep 2006
    That front looks cool! Can't wait to see it finished!
  13. Sleepstreamer
    23 Jul 2006
    Thanks Evenge!
    Managed to get the front mounted today, it's got one m4 thread in each corner which bolts to the case from the back so I won't get any visible bolts.
    The bracket:
    Threading the front.
    Some alcohol to keep the alu from sticking.
    The front is still not 100% finished, but at least now it sticks on without the help of masking tape.
  14. Azayles
    Azayles Member
    6 Jan 2008
    Looking super sweet! Stealthed tap holes Cheesecake :p
    What are you using to tap the holes? Looks like the chuck of a power drill from the pictures.
    Edit: I didn't realise "FTW" was turned into "Cheesecake" xD
    Edit 2: Oh dammit lol :eyebrow: :D
  15. Sleepstreamer
    23 Jul 2006
    Cheesecake is "Cheesecake" because Cheesecake has always had that special taste of Cheesecake, you know? :lol:
    Yeah I couldn't find my tapping tool (translation please) so it'd have to do, worked fine though!
  16. Azayles
    Azayles Member
    6 Jan 2008
    I went to put in "for the win" and it turned it into cheesecake :p
    How long's it done that?
    And damn you DID drill it?! Hard core xD Thought that'd give you too much speed? Or it a variable speed drill with lots of muscle behind it?
  17. Sleepstreamer
    23 Jul 2006
    Don't know exactly, but I think it started before you registered. You've clearly not been paying attention :p
    Well if you put it into high torque and keep it straight there's no problem. Only works on the smaller threads though like M8 and below, after that it gets really hard to keep the tap straight because of the tourqe needed to turn it. I really do recommend these spiral-taps instead of the ordinary straight-flute ones though, easier to work with and they don't get packed up with shavings halfway through.
  18. aeidau
    aeidau Industrial Designer
    13 Mar 2010
    Amazing build you have created I wish I had the skills and access to tools to make something as good as this :D
  19. Azayles
    Azayles Member
    6 Jan 2008
    Probably I never typed "for the win" on this forum before, but yeah as you said I probably wasn't paying attention :p
    I must get myself some taps, wonder if ScrewFix do the spiral ones?
    Edit: looks like they do :D
  20. Spyrious
    Spyrious Modding all the Time
    8 Dec 2008
    Very industrial.I like it very much.Very nice details.
