Scratch Build – In Progress Project: Prime - Update: May 21st - Yes, really
Discussion in 'Project Logs' started by Sleepstreamer, 1 Nov 2009.
  1. Shadow703793
    Shadow703793 What's a Dremel?
    5 May 2009
  2. DeadP1xels
    30 Nov 2009
    This is looking super cool!
    Awesome work
  3. Waynio
    Waynio Relaxing
    20 Aug 2009
    Marvelous :clap::thumb:.
  4. h2oextremePCs
    h2oextremePCs What's a Dremel?
    24 Nov 2009
    Excellent work, what software are you using to designt the CNC parts?
  5. Combatus
    16 Feb 2009
    :jawdrop:
  6. Evenge
    Evenge Minimodder
    16 Sep 2006
    That teaser looks really interesting.
  7. Sleepstreamer
    Sleepstreamer I modded christmas!
    23 Jul 2006
    Thanks for your patience guys ^^ It's been a slow couple of weeks but I think I'll get some done this weekend. Also, that teaser has been completed and I'll be picking it up later tonight for some photo cheesecake.
    Thanks!
    I'm using Rhinoceros 3D for all the cad-work and Galaad for the CNC.
  8. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    i think that is a really really god idea:D !
    and h2oextreme, plz dont quote that many pics! i thought it was an update:(
  9. Cheapskate
    13 May 2007
    If you kill Sleepstreamer's bandwidth limit, everyone will be sad.:(
    -Never heard of Galaad. *runs off to Google*
  10. Sleepstreamer
    23 Jul 2006
    Heh yeah you'll have to bash Dennis publishing on that one since I'm using the forum albums :thumb:
    It's arrived!
    But first, some snow-shovelin' :brrr:
    With that done...
    I'm actually a bit stunned myself of how good it looks :jawdrop:
  11. PimPin>PC
    PimPin>PC NZ Modder
    15 Feb 2010
    Man that thing is looking absolutly awesome :thumb:, that is some wicked crafting dude :hip:
  12. Azayles
    Azayles Minimodder
    6 Jan 2008
    Looking gorgeous that :D And I don't begrudge you shovelling that snow!
  13. sheptacular
    sheptacular What's a Dremel?
    11 Feb 2010
    sub'd for sexy... keep it up :thumb:
  14. Achron
    Achron Cad Pro Quo
    28 Nov 2009
    Did you waterjet the grill out or just use a really small end mill? I can't tell if there's a radius in there or not.
  15. Sleepstreamer
    23 Jul 2006
    Actually the grill was cut using a Fanuc Wire-EDM which leaves a small radius depending on what kind of wire you're using (roughly 0.15mm in this case), the rest of the piece was done in a Mazak VTC 300C.
  16. Achron
    Achron Cad Pro Quo
    28 Nov 2009
    EDMs are beautiful. Fanuc, on the other hand *gag*. Very nice, however, definitely a beautiful piece.
  17. stonedsurd
    11 Mar 2009
    I agree Achron. EDM is an awesome way to machine stuff. That plate looks great Sleepstreamer :thumb:
    With paint and a little gloss, it'll look phenomenal.
  18. MugenUK
    MugenUK What's a Dremel?
    5 Aug 2008
    That really looks gorgeous, looking forward to seeing the end product.
  19. Sleepstreamer
    23 Jul 2006
    Actually had time to make some progress on the stealth this weekend!
    Started off by mounting my atx backplate.
    With that done I could do some work on the stealth. Remember those pieces I earlier planned to use? I scrapped em... (Why do I even bother with making drawings? :p). Anyways, the new one is running with the same corner-cut theme as the rest of the case.
    TIme for a new sheet :thumb:
    And after 10mins in the router plus some bending action:
    Plus something to hold it in place.
    After looking at this for quite a while from different angles I decided that the acrylic piece should be in alu to fit the theme better. This would also keep it from flexing.
    It's now starting to look like I want it to :clap:
  20. DAE_JA_VOO
    DAE_JA_VOO What's a Dremel?
    11 Nov 2005
    Dude, that looks amazing. If you did that with a router in 10 minutes, I need to get myself a router ASAP.
