I am pleased to announce my new sponsors: Seasonic and Demciflex! Seasonic will send me a Platinum PSU and Demciflex will send a kit of dust filters for the Enthoo Primo.
A very big Thank you to Seasonic for supporting Project Prime with one of their powerful platinum PSU! More unboxing pics to come tomorrow. Stay Tuned!
Thanks to Nanoxia, they sent me PETG tubes and CF1 blood red coolant The new wrap arrived today, i also changed the pattern on the side sponsor plexyglass to match the new one. I know the sponsor logos are slightly crooked, i rushed on that ;( Thanks to Phanteks too, who sent me a Side window panel to mod. Any advice of how to cut the steel? I want to make the small window as big as the other one
A friend sent the pattern which i sent to print on a webstore, check in ebay there are a lot of mimetic wrap, i just wanted mine as near as possibile to the camo on the motherboard
I worked on the side windowed panel today, the cut was made with a Dremel 3000, sanding and then wrapping. Need to get the plexyglass in place, i will use the original one for the big window and i think a clear one for the sponsor side. Let me know what do you think of this mod
Project Prime has been nominated for the MOMT of BIT TECH FORUM, if you would like to help, please vote for Prime by Mark011 http://forums.bit-tech.net/showthread.php?t=282062 Thanks
I don't mean to hijack your thread, but is painting fans that can be done on all fans? Or only certain types? On a on topic note, the build looks great!
you can paint every fans! if you like the build don't forget to vote http://forums.bit-tech.net/showthread.php?t=282062
I'll check out the voting Is it a difficult job to do? I recently bought some Be Quiet Shaddow Wings, or silent wings?! I forgot... Anyway, I wouldn't mind painting them white..
You have to disassemble them, the frame from the body before painting, it's not hard, you need to sand, prime and paint, took some times for a good result
Parcel from Demciflex arrived today! Here some pics Today i bought a new tripod and took some high res pics with my DSLR Today i modded the other side panel too, i made a small window for the SSDs, need to finish this panel btw.
