Case Mod - In Progress Project: PrometheusCU - Update #54 - May 28 2010 - Video Teaser
Discussion in 'Project Logs' started by Langer, 18 Jul 2008.
  1. Htr-Labs
    Htr-Labs What's a Dremel?
    16 Jun 2008
  2. Langer
    Langer Jesse Lang
    24 Jan 2004
    That's just what you want us to think.
    Who is this 'We' you speak of?
  3. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    The still is an epic thread derailment Jesse. Of all the crazy things I expected to see in this thread, this certainly wasn't one of them! :D
  4. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    he lives in Virginia, that might narrow the question down a little...
  5. talladega
    talladega I'm Squidward
    18 Aug 2007
    virgins? :lol:
  6. jhanlon303
    7 Sep 2006
    You know this project has almost everything in it. Maybe Langer needs to toss in some solar panels, a little wind tubine, etc. What did I miss he hasn't thought of yet?
    john
  7. Mino
    Mino Ganzerli Mino
    5 Sep 2006
    Tnx a lot for not planning to water cooling the scsi card, Langer, now my wife has loose the bet, so she have to pay a drink to me :)
    Now I go to drink a free Negroni, I love free drink (and I love to win this kind of bet)!
  8. slisgrinder
    slisgrinder Minimodder
    14 May 2008
    if only you bet on arduinos...
  9. Htr-Labs
    16 Jun 2008
  10. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Could one overclock a cpu to the extent that it could make water boil? Then you could truly integrate the still into a pc! :he he:
  11. talladega
    18 Aug 2007
    water boils at 100C, IRC. CPU's cant run that hot.
  12. slisgrinder
    14 May 2008
    hmm...what if we make it run that hot??? what is to happen then??? whoever has a pentium lying around...please try to overclock it to 100C and see what happens...we are all waiting eagerly for the results...
  13. jhanlon303
    7 Sep 2006
    I think my P4EE at 3.0Ghz that's going back in the DragonHolm project could probably get that hot if I OC it a pinch. It is the hotest CPU(temp wise) I ever owned. I have had it to 3.3Gz on air but it heats a lot and I left the case open and put it on the floor with a 20" box fan blowing on it.
    3.6Ghz will boot but won't run XP Lite for long.
    john
  14. MonkeyNutZ
    MonkeyNutZ Crysis Fiend
    5 Jun 2007
    I have a 1.44GHz Athlon Thunderbird (Socket A) that runs at around 70c. The max temp is rated at 95C which is SO close!
    This build can't be described in terms of awesomeness :jawdrop:
  15. Burnout21
    9 Sep 2005
    dont need to get to 100 C as alcohol boils at a much lower temp, anyway back in the day OC dual xeons would be screaming along at 98 degree's thermal shut off was 120! that was the best bit about buying a xeon, there designed to work in super hot conditions at full load.
  16. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    78C is the boiling point of ethanol so could be done :)
  17. slisgrinder
    14 May 2008
    thats lower than the gpu temp of my lappy:D
  18. headala
    headala What's a Dremel?
    9 Oct 2005
    OMG I laughed so hard my wife gave me a dirty look 'cause she can't hear the TV. Thanks for making my night :thumb:
  19. Toka
    Toka Minimodder
    19 Nov 2006
    Run the still at a-bit-less-than-atmospheric-pressure
    Problem solved :)
  20. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    no update or new pics?
    my life has become so drool-less and bleak
    lest see this munster progress into a full blown MONSTER!
