Scratch Build – Complete Project Pupp3r
Discussion in 'Project Logs' started by MLyons, 7 Aug 2019.
  1. MLyons
    MLyons Half dev, Half doge. Staff Administrator Super Moderator Moderator
    3 Mar 2017
    Update coming today
  2. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    Woooooooo :rock::rock::rock::rock::rock:
  3. MLyons
    3 Mar 2017
    IT LIVES. Proper update later but thought I'd put this up for now
  4. BigShadow
    BigShadow New Member
    10 Feb 2020
    Looks cool, are you water cooling?
  5. yuusou
    yuusou Well-Known Member
    5 Nov 2006
    It's not cool until it's water cooled...
    I'll get my hat.
    MLyons and The_Crapman like this.
  6. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Air intake at the bottom, exhaust at the top?
  7. Cheapskate
    13 May 2007
    Looks like you still need a hole for the back of the gpu heatsink. -If that's where it vents.
  8. MLyons
    3 Mar 2017
    If you can find a spot I'll give it a go but I think that'll be for V2.
    Yup. I feel like the stack effect is under utilised in modern cases so thought I'd try to implement it here.
    Where the IO is? If so It's got holes there for the IO but those will be in the proper build log post.
    Post might be delayed until tomorrow due to blowing up a PSU earlier but I think you'll all like where's it's at.
  9. BigShadow
    10 Feb 2020
    you can find a spot at the panel that is not on in the photo and put there the radiator, or you could try some slim fans and se the clearance on the top, the gpu tho idk if you could make the case like 3cm taller you hade the space that you needed to the radiator(s), but for an AIO i think in the top you can try to see if you have space
  10. MLyons
    3 Mar 2017
    To make it talller I'd have to redo all the panels. On V2 I'll be making it bigger and fitting a water cooler in. Currenttly an AIO would interfere with the power cable of the psu
  11. Defyant Mods
    Defyant Mods Well-Known Member
    14 Sep 2004
    Looking good ML :rock: a smart use of space too! :thumb: where did you get the cool little corner screw blocks from ?
    Damm makes me wanna get back out into the shed again :dremel:
  12. MLyons
    3 Mar 2017
    Praise from you is great. It was you that inspired me to finally make my own case with your lightblade project.
    @Maki role sourced the blocks for me. I need to redo a few of the panels as you can see my lack of skill showing but overall it works well. The gpu temps are perfect and I think I can fix CPU temps with a small noctua cooler pointing upwards.
    Defyant Mods likes this.
  13. kim
    kim hardware addict
    10 Jan 2016
  14. MLyons
    3 Mar 2017
  15. kim
    kim hardware addict
    10 Jan 2016
    OMG :jawdrop:, you're right, I did not notice the price: :wallbash: : £44.99 for 10 pieces :duh: that's crazy
  16. BigShadow
    10 Feb 2020
  17. Cheapskate
    13 May 2007
    If I remember correctly, he found them at one of the major online electronics shops.
    I meant the part on the other end of the card, where they usually have exhaust venting. -But if this is just a ramp-up for a WC setup, let it be. :D
  18. MLyons
    3 Mar 2017
    Build is done and everything works. Just waiting on the fancy pants pictures from creative and it will be all done.
  19. Cheapskate
    13 May 2007
    Did you remove the masking, or leave it on for the Prius with a giant vegan bumper sticker look? :D
  20. MLyons
    3 Mar 2017
    Super sexy shots with the plastic off coming soon. For now you'll have to deal with the naff shots I upload in a bit.
