Case Mod - In Progress Project : PURE "FINISHED"
Discussion in 'Project Logs' started by subset7, 22 Mar 2009.
  1. stonedsurd
    11 Mar 2009
    Congrats on the [H] award and getting it (almost?) done!
    Looking sex-ay! :D
  2. wahoomcdaniel
    wahoomcdaniel What's a Dremel?
    14 Nov 2003
    Your work is as clean and thoughtful as I've ever seen. Excellent final product.
  3. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    man, this is one clean lookin rig subset. I love it!
  4. The boy 4rm oz
    10 Apr 2008
    The grills look really great, very spiffy, I must get some from Bill ;).
  5. mnpctech
    21 Apr 2003
  6. SkiDave
    SkiDave Minimodder
    16 Mar 2008
    :thumb: They look awesome!
  7. UltraModder
    UltraModder Play Hard!
    23 Mar 2009
    Im thinking of getting some of those grills for my build. Going to have a bunch of new fan holes to cover the silver and black will make my case match my blackberry storm. :)
  8. subset7
    subset7 Spanking the Monkey
    31 Aug 2008
    Thanks everyone :thumb:,Yea the grills are great the quality of the finish is second to none,i'm really pleased with the way they look.Well,I had to work at the weekend so I didn't get anything done,got a busy week this week and the week after i'm going to Prague so this is going on hold 'till I get back.
  9. mnpctech
    21 Apr 2003
    Have a safe trip subset. I look forward to seeing the next update when you return :thumb:
  10. subset7
    31 Aug 2008
    Been a while since I last updated this as I haven't had much time lately,anyway I sleeved the power/reset switches individually
    Fitted back in the case
    I got two of these displays to monitor the water temperature in the two res's
    These are going in to one of the 5.25" bay covers which i've marked out
    And after a few cuts with the Dremel
    Before the displays go in I wanted to spray them white,which means dismantling them,to do this you need to cut the retaining slots on one side
    Cut out with a sharp knife
    Tha back should just pop open then
    Tha PCB removed
    Now i'm left with the piece I want to paint
    Sprayed and clear coated
    Test fitted in the cover
    Just need to reassemble them now,I hope to get this finished at the weekend that's if the missus doesn't get on my case about doing the garden,it's starting to get a bit wild out there :)
  11. Gaoske
    Gaoske What's a Dremel?
    10 May 2005
    This mod really looks very clean!! PURE and basic, VERY nice!!!
  12. Odin Eidolon
    Odin Eidolon What's a Dremel?
    7 Feb 2009
  13. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    you use a LOT of cable sleeving, it's great to see! Furthermore the top is as KILLER, it really, really looks good!!
  14. stonedsurd
    11 Mar 2009
    Another stunning update :thumb:
  15. subset7
    31 Aug 2008
    Thanks Gaoske :)
    Thanks Odin Eidolon :)
    Thanks jegerjon :)
    Thanks stonedsurd :)
    I've reassembled the displays and done a quick test just to make sure they were ok
    Everything seems fine so i'll solder them up to the sensors in the res's tomorrow.
  16. woody_294
    woody_294 Wizard Ninja :P
    31 Dec 2008
    Great mod man! I'm subbed, looks to be a nice clean build :)
  17. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Looking great so far :thumb:
    Where did you get those displays? or what are they at least? I've been looking around for something like that for a possible build on a Corsair Obsidian.
  18. The boy 4rm oz
    10 Apr 2008
    Looking good. I like the sleeving job on the power and reset switches, very nice. Also nice mods to the LCD temp displays, you'd think they would make a white version also considering how well yours turned out :D.
  19. mnpctech
    21 Apr 2003
    Nice update subset, this build rawks :thumb:
  20. subset7
    31 Aug 2008
    Thanks woody :)
    Thanks [ZiiP] NaloaC,I got the displays from Here :)
    Thanks The boy 4rm oz,aye you would think they'd make different colours :)
    Thanks Bill :)
    Well this is finished now apart from the lighting,I need a couple of extensions for the CCFL's,so I wont post the final pics untill I get them fitted,but here's a couple of pics of the front with the displays in
    Final pics to follow soon
