Thx guys for your support. It's my first homemade and i m quite happy of the final result. Now, i m gonna prepare a new mod. But i have to create all the sketches so its will take time. I will post more photos of my mod later with few modifications
Great mod, especaily becuase tis your first home made mod, I look forward to the next mod... I only caught this mod in the final stages, but looking back on it, I sure missed a lot. A great deal of care and attention was put into it!
That is pure clean case u made there loved the idea to paint it and the chrome fans look great well done on completing it at last cant wait to see ur next mod though
thx here are some few modifications. I integrated a thermal screen on behind the front fan To Be CoNtInUeD ...
Thats a great case exterior, but when the flap is open, imo theres to much empty space. IE: make a panel to go around the rheobus so it doesnt sit out in space like that. Also the hinge area and nest to it could be covered up. If you covered the blank areas inside the flap, it would look juts as good no matter if the flap is open or closed.
Yes i agree with you. I will try to do this modification A panel that i will fix on the box to see only the trap and the rheobus Thx
I love that layout!! I have to give you huge props for managing to fit all that in there the way you did, nicely done!!!!
So clean and dam perfect, and the fans dont spoil it either, they enchance it, although i think the drive bay could be positioned in a way that looks better
thx guy for your support Here what i ve done this few weeks, a flash gallery of PuRiTy (not yet finish) http://ravi37170.free.fr/images/ravimade/simpleviewer/purity/purity_diapo.html
