Project Purity & Simplicity Chrome and Black (Project on hold for a little)
Discussion in 'Project Logs' started by Robster, 1 Feb 2004.
  1. JEEVES
    JEEVES Minimodder
    14 Jul 2003
    where did you send these to get painted and about how much did it cost (if you dont mind me asking).
    JEEVES
  2. FILTHY1337
    FILTHY1337 Senior Overclocker
    4 Jan 2004
    the top panel looks like it has alot of blemishes (or dust) but other than that it looks awsome :thumb: edit: oops missed that little bit bout the rag
  3. hercule
    hercule What's a Dremel?
    19 May 2004
    wow, i can't believe how well the front turned out. Love the shine :D
    great job
  4. Robster
    Robster What's a Dremel?
    11 Dec 2003
    sent them to a local auto paint shop here in Edmonton called VANART Customs these guys have done lots of custom cars here in the city and it costs $200 for the paint job was deffinatly worth spending the money to get the car finish
  5. alianyn
    alianyn What's a Dremel?
    8 Nov 2003
    damn! (sorry) chrome is SO nice!
    that`s the best looking chrome (on the fornt panel) job i`ve seen to this date! looks amazingly well and fits - like a hightech car.
    keep on (if $$ ofcourse permits - me ofcourse it does not permit... ;P) :dremel:
  6. Nexxo
    23 Oct 2001
    That black laquered front bezel looks almost kinky... sort of all curves and black PVC... :D But perhaps that's just my warped imagination. In any case it looks very pro, like one of those expensive organic HiFi speakers.
  7. jezmck
    jezmck Minimodder
    25 Sep 2003
    I reckon you should rename it 'Project Purity & Shinyness'
    looks amazing.
  8. Robster
    11 Dec 2003
    Well still waiting on parts to come in for a few projects so decided to do something tonight.
    Made some of the lights for this mod as it is going to be all white lights and I really don't want to use cold cathode I decided to us strictly leds.
    I had these from a previous case the housings were made by Antec they worked for a while but the original leds burned so got looking at them and they have a chrome housing which helps to spread the light from the leds. :idea:
    So seeing as some of the leds were burned out anyways why not put it to good use and switch all the leds for white ones see if we can get the light we need.
    Here are some shots of the White led's in this these are bright they will light up the inside of the case really well and I have 2 of them. :cooldude:
    I know there is one led missing time to go to the supplier and get some more I don't know what it is but seem I buy lots and never have enough always end up needing one or two at the worst time.
    Well that is it for now should give you a better idea on the lighting.
    I will be getting the other side panel back from the paint shop on Monday and will be getting some smoked plexy for the windows on Monday as well so will try and get some pics of these posted then.
    Till then have fun and keep modding
  9. toss
    toss What's a Dremel?
    6 Jun 2004
    Looking good man cant wait to see the final product
    [:clap:]
  10. Nevex
    Nevex What's a Dremel?
    25 May 2004
    Why didn't they color sand it? Got some mean orange peel effect.
  11. Robster
    11 Dec 2003
    Yah was looking at that in the photos it does look a little off but in person it doesn't look as bad guess the camera is picking up stuff i can't see but the paint shop has said that they are willling to redo them but because of time constraints on this i am going to have to take them this way and maybe look at it after the show in July.
    But it still looks good and maybe after a good waxing should look even better.
  12. Kurtis
    Kurtis What's a Dremel?
    9 Apr 2004
    just wondering, are your side panel reflections all distorted looking in real life or just the pics?
    btw, nice job on the duct molding... i'm trying to get mine to be perfectly smooth and it's not easy at all... did you just use bondo? and how do you get rid of small imperfections? Spot putty doesn't seem to want to do the trick even...
    Edited to remove pics from quote - Mister_Tad
  13. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    <Mad viking!> FOR CHRIST'S SAKE!! Delete the pics when you quote!!!! Why can't anyone (I do not mean the hardcore forum users) cut away the pics from their quotes!?! </mad viking!>
  14. Acid Burn
    14 Mar 2004
    btw: very very nice finish (and job) on that paint and bondo! i'm not sure if you have seen my project but, I'm going to do the same :)
    hmm... it would be fun to start a thread where everyone tells their age :)
  15. Robster
    11 Dec 2003
    The bondo work was just about time and lots of sanding and patience but it was worth it as for the panels the don't look as distorted in person i still have to use a rubbing compound and wax them so they should come out nice then this just letting the paint cure for a few days before doing this.
  16. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Pacience is indeed the key, just like in project divergence...
  17. jezmck
    jezmck Minimodder
    25 Sep 2003
    ditto
  18. SMOVE
    SMOVE What's a Dremel?
    17 Apr 2004
    Whoa the chrome looks so sweet :D :rock:
  19. Mister_Tad
    27 Dec 2002
    yes, please do in future for posts like that
  20. JungleGorilla
    JungleGorilla What's a Dremel?
    21 Apr 2004
    That front bezel is look'n damn sexy :jawdrop:
    The ducts just set the whole thing off! :rock: :rock: :rock:
