Case Mod - In Progress Project: Purple HAF
Discussion in 'Project Logs' started by TheGreatSatan, 9 Jan 2012.
  1. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    As you're about to see, I really like the Cooler Master HAF 912. I used it for my AMD Bulldozer mod and now I'm using it again. This time, however it's going to be my daughters' (I have two of 'em) new playroom PC. They currently have an HP Slimline that is four years old. It features the first AMD dual core, the Athlon X2 3800+, 2GB of RAM, a 250GB HD and the GeForce 8400.
    Nothing super fancy, just a mod for my kids
    Once again I stripped the whole thing down to the base metal
    And blasted it with Krylon Plum paint!
    And I painted the front panel mesh purple too
    All of the original black plastic will be repainted to white
  2. TheGreatSatan
    5 Aug 2005
    Once the paint had dried, I reassembled the front bezel
    And added the 200mm UV purple fan
    Next came the DVD drive and Cooler Master logo
    I painted the hard drive bay white to contrast the purple. Funny this is, I won't even be using a 3.5 inch drive
    Next, I finished painting the right panel
    Time to look at my components. First off is the PC Power & Cooling 600 Watt modular PSU
    I scoured my modding area looking for DDR3 and found two 4GB OCZ sticks and two 1GB Crucial sticks for a total of 10GB of RAM!!
    Here's my motherboard. It's an AM3+ board too just in case I only want to swapt the proc in the future. I even bought two Purple SATA data cables.
    I'm going to add the PSU to the case first
    Except that I don't want the Volts/Amps sticker on top of the PSU
    The water cooling gromets went back on too
    I put the Processor and memory on the board, but I can't test it till I buy a heatsink
    I love that the PSU is modular. I only need to add the one SATA power cable for the hard drive and DVD. One of the SATA leads will be adapted to power the lights and fans in the case too
    I've already added one of the purple lights to the drive bay. It should shine on the video card
  3. Pranja
    Pranja Blackwolf
    18 Dec 2011
    No pony's?
  4. Briaireous
    Briaireous New Member
    29 Nov 2011
    The name of this mod caught my eye ;) haha
    The white and purple go quite well together, i'm interested to see more :)
  5. jeckulz
    jeckulz New Member
    18 Jan 2011
    Just a heads up mate, I had one of those purple LED clusters in my case for a bit- total crock of ****, not bright in the slightest. I think the problem is that it spreads the LEDs focus spot too wide. My advice, get cathodes or strips.
  6. AK71
    AK71 New Member
    29 Jul 2011
    Very nice so far. Good to see other people using different colours too!
  7. TheGreatSatan
    5 Aug 2005
    I'll have two UV cathodes too
  8. spigs_rex
    spigs_rex Member
    1 Oct 2010
    thats a sexy purple lol the white goes well with it
  9. TheGreatSatan
    5 Aug 2005
    I picked up a Cooler Master S524 Heatsink
    But decided it needed to have a 140mm NZXT fan instead
    The Sapphire 6770 is a stupid amount of overkill for this build
    And I still have to clean up the wiring, but I'm still waiting for a few more parts
    The PC boots just fine. I hate how there's no longer a screen that says what processor you're using and how much RAM is installed
    One thousand posts and it only took me 6 years!
  10. TheGreatSatan
    5 Aug 2005
    I got these great 120mm UV Purple fans on eBay. These are hard to find!
    Two are intakes on the front
    And a rear exhaust
    Then I painted the 2.5 inch drive adapter to match the bay
    I'm using a Sandisk 120GB SSD. This will be the only hard drive in the system
    And its mounted in the bay
    I also added two UV cathodes to the case
    Now to add the window
    I wound up going a bit bigger then I originally had planned, covering the HAF logo
    But I made a stencil so I could put a new, slightly smaller one in it's place
    Next I paint the panel. Actually I already have, but it's coming out like crap
  11. spigs_rex
    spigs_rex Member
    1 Oct 2010
    ah shame about the panel such a pain redoing hard work lol ...other than that its looking very nice n clean! :)
  12. Cheapskate
    13 May 2007
    'Too cold to paint anything' is my first guess. It looks like the paint isn't sticking and running off.
    The pitting is easy: Your jig saw is throwing oil.
    Yeah, it took you 6 years to make 1000 posts, but look at the content you put in them. If you did one picture a post, you'd have more posts than Bindi.
  13. KidMod-Southpaw
    28 Sep 2010
    Congratulations on your 1000th post! And shame about the panel, only worth trying again when it's hotter.
  14. Conica
    Conica New Member
    12 Jan 2012
    Love the idea of a Fun PC for the kids, May wind up doing something similiar myself down the line.
    Don't stress about the paint, I agree with the above posts about it probably being too cold and the pitting may be thrown oil, Or possibly just the unmixed paint in the bottom of the can contaminating it.
    Oh, and this is my first post, But Congratz on your 1000th :)
  15. TheGreatSatan
    5 Aug 2005
    I was thinking about how attention to detail could make or break a project, so I painted the slot covers too
  16. skreenname
    skreenname SFF Forever
    11 Jun 2009
    You should paint the I/O panel white too.
    Make it match the rest~
  17. TheGreatSatan
    5 Aug 2005
    I'm not pulling out the board at this point
  18. TheGreatSatan
    5 Aug 2005
    Here's the mesh I used to cover the back of the GTX 560 on my OCZ mod
    After I cut it to size, I also cut out a piece of paper to use as a substrate
    Then I painted the mesh
    And I used some double-sided adhesive tape
    To bond the paper and mesh to the card
  19. Cheapskate
    13 May 2007
    You can't paint the material on the I/O plate anyway. HDPE is a non-stick surface. -vinyl tape?
    In fact, white electrical tape would be good for a cheap accent material.
  20. Pranja
    Pranja Blackwolf
    18 Dec 2011
    One tip:
    When using spray cans, put them in a pot with boiled water,turned up side down and hold them for a couple of minutes. That will melt paint and you will avoid what happened on side panel.
