................................................... That's all I can contribute without drooling all over myself
[WP@]WOLVERINE how much begging would it take to get you to create an etching guide for us less skilled modders? You're work is amazing.
Nothing actually because i already did and Acid Burn translated it for me (cause im a lazy sod ) Here it is http://forums.bit-tech.net/showthread.php?t=66671
-Small update- Ive finished all the etches now and begun construction of the base that will contain the psu,cd,diskdrive and hdd. Ive got the basics done on the base and im currently making the mb mountigplate and all the other little things that is needed to screw all the hardware in place. Theres also some fanholes to be done. Heres a picture of the case as it is. Nevermind the frame i put together its just so that i would have someting to lean the sides against. I will do a real frame from aluminium on friday. This is just to get some ide of what it all may look like. Theres still alot to do on the base to make it really hellraserish
Thanks for the link [WP@]WOLVERINE. That was an instant bookmark and thanks for the translation work Acid Burn.
hehe this mod is turning out just like we all predicted... Outstandingly amazing (if that's a word ). How are you going to hold the case together?
ALL SHALL WORSHIP [WP@]WOLVERINE PRAISE HIS ALMIGHTY COMMAND OF THE MODDERS BEST FRIEND KNOW ONLY AS THE " "
Sorry if you've written this earlier in the thread, but is this done with a dremel? If that is right then
All his work is done with a dremel. Read through the thread you'll find a link to his other case and between these two threads you should find all your questions answered.
Yepp thats right its all done with an old dremel, the one i use i actually the first generation of dremels so its not electronic. Its just the dremel with no artificial additives or preservatives of any kind
-=Update=- Ive got the sunblock film in place now so i had to show you guys how it looks Heres some pics This is just a teaser of things to come
that's incredible what you ve done with the perspex when I see these pics the only thing coming to my mind is that you ve got dremels on your hand just in place of your fingers can't wait to see the case done
omg! that looks amazing!!! is it just window tint on the back? is it possible to see light throug it? are you going to engrave the pattern you've drown on the wood base?
Its sunblock film the same kind you use on car windows. The wood base will most certainly be engraved in some way but if its going to be the first sketch i did i dont know.
OMG, thats pretty freaky Just got the chills from seeing the etchings. I'm trying for weeks now to get 1 simple etch done and I can reassure you its very hard to get it right. I consider this ART congratz greetz, Joungne
