Project PX03 Darkcrystal wOOdcase FINAL PICS
Discussion in 'Project Logs' started by piloux, 12 Nov 2003.
  1. piloux
    piloux What's a Dremel?
    12 Nov 2003
    hi everybody , first i ask you to sorry myself because my english is very bad and i hope you understand me but pics are better than words :D
    so my project is a selfmade case in lexan/wood ; all the internal structure will be in lexan and the exterior in wood and lexan (thanks to eddie the dane 's guide that gave me inspiration :thumb: ) the last part of the case will be a black shiny painting of all the wood parts
    the cut for blowhole
    Tulatin likes this.
  2. piloux
    12 Nov 2003
    her wil be place the crystalfontz lcd
    here is the case structure
  3. piloux
    12 Nov 2003
    and the panel with the window's hole
    the place for drive
    then i put some mastic on it
  4. piloux
    12 Nov 2003
    mastic again
    and after sands paper
    well i return to english lessons before update :D hope you enjoy my work
  5. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    :rock: that's lookin really good. I tip my hat off to ya on cutting holes after stacking the layers... that's a gutsy commitment but it looks like everything is paying off.
    I'd like to know more about the stuff you are putting on the wood prior to sanding. My understanding is that mastic is a masonry adhesive but I could be wrong what you are doing with it.
    That's going to look awesome lit up.
    eddie looks into crystal ball.... I see a lot more sanding in your future....
  6. Eaglespirit
    Eaglespirit What's a Dremel?
    27 Sep 2003
    looks very nice, hope the lexan will give enough light.
    Is it heavy? How will you paint it without "destroy" the lexan?
  7. piloux
    12 Nov 2003
    thanks for your comments :)
    eddie dane> first your i love your case :thumb: for the mastic you re wright, it is adhesive and when it is sanded i give a good surface to paint
    eagle spirit> its about 7 kg (i don't know the conversion in pound)
    and for the light i made a test and it goes well
    it will comme some others lightning in it :)
    i ll paint the case by hidden the lexan with professionnal adhesive paper
  8. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    wow.... if this one will be better than vespadeco or something, I will worship you for the rest of my life!!! I know it will be better...
  9. Eaglespirit
    27 Sep 2003
    ok, it wasn't so heavy as I thought. And the lights look very good. Maybe LEDs? They have much cleaner light, but it's expensive.
  10. Lord Kordir
    Lord Kordir What's a Dremel?
    5 Nov 2003
    OOOOOO :jawdrop: Very sweet!
  11. piloux
    12 Nov 2003
    RAMeLair > i just look up this project and it seems to be good too :)
    eagle spirit> i m going to use leds fans and some ccfl hidden into double panel in the case just to light front and top
  12. penski
    penski BodMod
    29 Aug 2002
    If you have a little trouble with your English then someone will point relix at this thread - His English is pretty good :) He'll help you translate and stuff.
    Nice case, man :)
    *n
  13. piloux
    12 Nov 2003
    thanks ;) , current language is not so hard for me , thats the technical terms/words that made problems with me...
  14. FlashPanHunter
    FlashPanHunter What's a Dremel?
    22 Aug 2003
    This case is very good. I love the wood combined with the plexi, it looks great like that. I cant wait to see it painted. Good job :thumb:
  15. iStormy
    iStormy What's a Dremel?
    5 Nov 2003
    That looks great! I was actually planning to do something very similar, all the way down to the black paint and blue plexi, after I finish my current case.
  16. Solarius
    Solarius What's a Dremel?
    3 Oct 2003
    Drat, not pics for me.. just red squares.. :(
  17. sambo
    sambo What's a Dremel?
    16 Jun 2003
    me tooo :idea:
  18. legoman666
    legoman666 Beat to fit, paint to match.
    24 Aug 2003
    ahhhh beautiful, gotta love the red x's
    get them working!!
  19. piloux
    12 Nov 2003
    i just got a mail : multimania has just shut down my ftp :miffed: now i must create another
  20. piloux
    12 Nov 2003
    well it s done in few minutes i hope pics will be back
