Project PX03 Darkcrystal wOOdcase FINAL PICS
Discussion in 'Project Logs' started by piloux, 12 Nov 2003.
  1. The_Sub
    The_Sub What's a Dremel?
    16 Nov 2003
    I just thought that I would pop in and tell you that you are doing a fantastic job on this case. I really love the way you integrated the wood and plexi. Simply marvelous!!! I am patiently awaiting the finished product so that I may drool on my keyboard again.. :D :thumb:
  2. piloux
    piloux What's a Dremel?
    12 Nov 2003
    I don't know what happen with pics ! so sorry for this problem, it must be the host...
    for now I havent try the flame polish because the sanding finish take me lot of time (much more than I thought)
    thanks for your comment :) you ll have to be patient to see finish product because this painting is a very hard job and I have not lot of time to it for now
  3. djengiz
    djengiz Pointless.
    16 Aug 2002
    Nice stuff!
  4. Neomagic
    Neomagic What's a Dremel?
    13 Jan 2002
    Simply astounding work... never seen such nice handcrafted case in wood as yours. Keep it up my fellow Belgian ;) :clap:
  5. piloux
    12 Nov 2003
    thank you my belgian friend ;) happy to see compatriot here :)
    my stuff with painting is a little bit in stand-by because I have got enormously work at my jobsince one week but I hope that the next week will leave me more spare time to continue the project :)
  6. piloux
    12 Nov 2003
    it s the weekend then i work on my project, I have made a big mistake by using the green mastic which made cracks everywhere on the case :( then I put polyester mastic every where bu!t it takes lot of time
    her is the polyester i use:
    left and right panels:
    and some places where there were some cracks:
  7. piloux
    12 Nov 2003
    well, i have to sand the whole case now and after apply the filler and re-sand all to see where it always stand some imperfections...
    always lot of work on it , I hope to finish it this year but it is not on wright way for it...
  8. bsodmike
    bsodmike Banned
    11 Oct 2002
    :blah: Sorry to hear about the mastic :sigh: Can't wait for the end but take your time and get it right :D
  9. Thunder_return
    Thunder_return What's a Dremel?
    8 Jun 2003
    O Ouch! Sorry, it must hurt.
    Keep up the good work!
  10. SweMOD
    SweMOD What's a Dremel?
    16 Nov 2003
    I have never liked wooden cases...
    and still I don't...
    but you are making such a perfect and great finish with it so
    I just love your case!!
    You are getting all the scrathes away so it looks totally awesome!!
    i really love your case!!
    absolutely the best wooden case ever made!!
    // Chris
  11. Wicked Li'l Bender
    Wicked Li'l Bender What's a Dremel?
    9 Nov 2003
    All the world is a stage and the people are just Modders in disguise....
    must controll the begging for more updates...
    If you have any problem with the wood poking through the places you sand and it gets rough... use a wood sealer to make it harder and easier to sand smoothly... Sorry it came so late...
    :wallbash:
  12. piloux
    12 Nov 2003
    thank you all,
    wicked > I don't make lot of update for now because the sanding process is always the same thing and then pics are relativly the same, the problem dont come from wood parts but from the green mastic i used first... thank you for helping me with your ideas
    now i m searching for another mastic to get a good finished surface, does anyone can tell me what is the best one I can use?
  13. McBug
    McBug What's a Dremel?
    18 Dec 2003
    Filler
    Great case, I am a woodworker here in the states and really have enjoyed this forum. Have you thought of trying car auto body filler? It's called bondo here in the U.S.
    McBug :thumb:
  14. piloux
    12 Nov 2003
    Re: Filler
    thank you Mcbug, yes i used body filler,
    this green color is car filler
  15. piloux
    12 Nov 2003
    I hope to find any free time this weekend to finish the sanding process, update soon :)
  16. Wicked Li'l Bender
    9 Nov 2003
    Sweet... I tjink that you are over the hump with this project... Keep going and millions of viewers will be tuned in for the :waah: Final dramatic episode when this thread comes to a close...
  17. Confusitron
    Confusitron What's a Dremel?
    22 Dec 2002
    Fantastic work! Fantastic! Fabulous! It looks so perfect. I'm amazed it's made out of wood. This thing is great. Just keep working! Keep working! Beautiful!
    A GLORIOUS PIECE OF WORK!
  18. 3vil-Grin
    3vil-Grin What's a Dremel?
    25 Jun 2003
    :rock: :rock: :rock: :jawdrop: :jawdrop:
    I read all the posts for this project to get up to speed with such a sweet looking case.
    Man...lots of work you have put into this case and it shows!!
    GREAT GREAT GREAT WORK!!!
    Cant wait to see the end result.
    Thank you!! :thumb:
  19. piloux
    12 Nov 2003
    thank you very much guys :D , the project goes on :rock:
    the end is near now :)
  20. piloux
    12 Nov 2003
    hi guys :) here is my work of few past days
    since lot of problems I had with cracks dues to my wrong use of finish mastic, I have finished the the wet sanding before apply the car filler and I put the masking tape too on the lexan parts
    the inside too
    and then I applied two layers of car filler
