Project: QbiX Water Cooled \o/ (aluminium cube)
Discussion in 'Project Logs' started by The_Resetter, 28 Mar 2004.
  1. DocSteward
    DocSteward What's a Dremel?
    12 Jun 2004
    this is very sweet.. I'm learning alot. great work. I'm Kindda new to this forum but so far I've like most of what iv seen. This one definatley rox. Keep up the great work. :D
  2. R@Mo
    R@Mo What's a Dremel?
    14 May 2004
    Didn't know LED's could be THAT bright!! Very nice work! Keep it up! :thumb:
  3. WeldZilla
    WeldZilla What's a Dremel?
    22 Apr 2004
    you have have done such meticulous work!!! I can hardly wait to get started on my next project!! Congratulations on your skill and patience. Look forward to seeing it in operation!!
    WZ
  4. Satan
    Satan Banned
    5 Feb 2004
    Amazing work, extremely impressed!
  5. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Wow they are bright, good work, I like what you are doing with this!~ :hehe:
  6. coorz
    coorz Miffed
    25 Apr 2003
    Hehe most Dutchies aren't really in the mood now, wild guess :miffed: .
    But now you make me curious, WHAT is in those boxes under yer bed :hehe:
    And the red LED bar is really cool, a slow controllable fade in or out would be a nice effect.
  7. The_Resetter
    The_Resetter I LIKE CAKE!
    6 Oct 2003
    Hehe I for one don’t care sh!t about that stupid football, so I don’t care, I’m glad they lost, no more orange houses :wallbash:
    And in those boxes are &rand moddin stuff and some magazines
  8. The_Resetter
    6 Oct 2003
    Small update, another side pannel done.
  9. richtea78
    richtea78 Guest
    Keep it up mate. I cant wait to see the finished cube. Im looking at the mountainmods cube now as I dont have your skills
  10. The_Resetter
    6 Oct 2003
    Teaser time ;), what you see here is a piece of plexiglas.
  11. JungleGorilla
    JungleGorilla What's a Dremel?
    21 Apr 2004
    Hah... I only just realised that the camera is a reflection!
    :thumb: Nice piece o' plexi you got thar
    [edit] that is the camera's reflection in the plexi right :worried: [/edit]
  12. The_Resetter
    6 Oct 2003
    Yes it is :)
  13. The_Resetter
    6 Oct 2003
    Almost forgot the holes for the dvd writer :)
    Now the back plate IO panel is finished, but I sleep next to my pc now i can coupe with some noise but I cant sleep with light on.
    So I’m gonna arrange that I can switch off every little light including that of the LED fans.
    Without wires.
    With wires
    And nicely covered with some “Hot Glue”
    Baybus time.
    Same effect as the larger chunk of plexi but this time 6 smaller pieces.
    And the front plate for the baybus, how will it all work and fit? Well just follow the thread and find out yourself
  14. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    wow, this case sure has come a long way. those bright red leds work a lot better in your case, plus then you don't have the inverter boxes to worry about.
  15. Firehed
    15 Feb 2004
    Wow, I just read through the whole thread and I'm really impressed. You've put in a lot of attention to detail and the case shows it! Let me know where you live and when you're finished so I can come by and swipe it!
    I like the LED bar thing too... I just don't have the slightest idea where I can get the right parts to make something like it.
  16. The_Resetter
    6 Oct 2003
    And the photo's with the drive installed.
  17. SuperFreak
    SuperFreak What's a Dremel?
    16 May 2004
    I like it! It looks really good, great job with the cd-rom!
  18. richtea78
    richtea78 Guest
    Ive been wondering about how to have lights seperatly from the fan power, any chance you can let me know how you did it? Im in the same situation with you regarding lights and sleep!
    Cheers
  19. The_Resetter
    6 Oct 2003
    Carfully check the pictures ;) I desolderd all the wire's the ones you can still see are from the leds.
  20. Balder
    Balder Calmer than a monk on morphine
    4 Jul 2003
    wow :jawdrop:
    'that looks fan tastcic :p
    these will most definatly be a sweet box!!
