Project: QbiX Water Cooled \o/ (aluminium cube)
Discussion in 'Project Logs' started by The_Resetter, 28 Mar 2004.
  1. Bilbo Fraggins
    Bilbo Fraggins What's a Dremel?
    1 Jul 2004
    GOOD CRAFT WORK! :dremel:
    i like what i see :D
  2. alianyn
    alianyn What's a Dremel?
    8 Nov 2003
    AWESOME! this rig is just getting hotter!
    actually the DVD turned out better than i thought, so i`m eating my hat on this one...
    can`t wait to see how the fan bus turns out - NOW here`s something i`m looking forward to - don`t take too long.
    well??? still not done? get to it - :rock:
  3. SMOVE
    SMOVE What's a Dremel?
    17 Apr 2004
    Really great modding work you do :thumb:
  4. vetlel
    vetlel What's a Dremel?
    7 Apr 2004
    @ The resetter:
    bit of topic:
    is that Borgcube yours?
    Now that's something to show off!!!!!! WOW
  5. R@Mo
    R@Mo What's a Dremel?
    14 May 2004
    Very nice work so far! Keep it up!! :D
  6. Halgy3000
    Halgy3000 What's a Dremel?
    22 Mar 2004
    Woah, this is sick.
  7. Zheele
    Zheele What's a Dremel?
    17 Feb 2004
    Did you create that mirror effect yourself or did you buy the plexi that way?
    Love your work btw.
  8. The_Resetter
    The_Resetter I LIKE CAKE!
    6 Oct 2003
    Nope, i dont have a cardbord pc :p i do know the guy.
    Did you even try to read the topic, or do you just watch pictures ?????
  9. Zheele
    17 Feb 2004
    I did read the topic. I even :search: Sorry if i offended you in some way. :wallbash:
  10. The_Resetter
    6 Oct 2003
    Then use your common sense !!!, what do you see a relection of a spray can, waaaaaaaaaaaaaaaaaauw could that have something to do with it ???
  11. [t0rc]
    [t0rc] What's a Dremel?
    28 Nov 2003
    First off, ace job. That's just an overall good looking project.
    I'd like to know, at this point, approximately how much time and money has gone into this project?
    :rock: :rock: :cooldude:
  12. icarus
    icarus What's a Dremel?
    18 Jan 2004
    cmon i need updates this thing is making me fecking hot and bothered. i need another hit of your funky modding s*it
  13. Poppa_joe
    Poppa_joe What's a Dremel?
    12 Feb 2003
    Nice work with the jewlers saw. I took a jewelry class in high school and used a saw just like that to cut silver. If you know what you are doing those things work wonders. I love what you have done with the case so far. Everything is so clean and sharp looking. Will you be able to see the PCB's that you etched when the case is finished? I think it would be cool to show them off. I like how simple you have kept the lines. Keep up the good work man.
  14. TomboyMS
    TomboyMS What's a Dremel?
    6 May 2004
    Impressive
    Great work. I can't wait to see more.
  15. The_Resetter
    6 Oct 2003
    A good friend of mine designed a logo for my case a while ago, and today I modded it into my reservoir
    So get ready for some home made window etches, makes for cheap and spunky moddin ;) [​IMG]
    I just printed the image I wanted onto the back of that plastic foil you use to give normal glass a matted effect, but it also makes great window etch material
  16. MrSaLTy
    MrSaLTy What's a Dremel?
    13 May 2002
    Dude that's supa sweet.. now throw up some pics with the res full and the lights on. :D
  17. The_Resetter
    6 Oct 2003
    That will have to wait till its finished :p
    I went to the aluminium guy a few days ago, and picked up a new piece of aluminium for a new sidepanel, when I asked if they had some of that “racing grill” and by jolly they had, I got a piece of that for free, I decided to incorporate that into the top panel, since this panel dint have a fan grill.
    Looks brilliant if you ask me :naughty:
    And a photo with the “Meteor Lights” turned on.
    And some eye candy, I was playing around with the camera makes a great background doesn’t it ;)
  18. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
  19. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Wow this keeps getting better and better. I hope you're not using the ECS K7S5A shown earlier :D
  20. The_Resetter
    6 Oct 2003
    Hell no, im using my epox 8rda3+ :p
