Project: QbiX Water Cooled \o/ (aluminium cube)
Discussion in 'Project Logs' started by The_Resetter, 28 Mar 2004.
  1. The_Resetter
    The_Resetter I LIKE CAKE!
    6 Oct 2003
    Well not all of it, just the copper parts will get the regular resetter style Bling Bling ;) hehe
    Yea I kinda noticed the disk wear down with a incredible rate, however im getting quite in love with those little figure saws \o/ it goes fast and leaves a nice clean cut.
    Ow and my hand are still fine (for the moment ;)) I just finished the second layer of slots. :dremel:
  2. djengiz
    djengiz Pointless.
    16 Aug 2002
    Hi instead of filing everthing by hand, you could make a template (with wood) and use the template to dremel along. This would be straighter and neater.
  3. The_Resetter
    6 Oct 2003
    Right, so after another hour or so , the second layer of slots it cut (ouch my back :()
    And no I dint do my hear :p
    Zaagu zaagu wiede wiede wage resetter kwam thuis om een boterham te vrage……. <-- Dutch song.
    And to make all that sawing a little easier im using some drilling / tapping oil. A modders best friend.
    Closeup of the figure saws, strangely it says for “wood and plastic” on the package but it works fine on aluminium ;) :lol: :hehe:
    After cutting.
    And finished, here and there a little error but hey nobody’s perfect. :p
    It even fits the radiator ;)
  4. The_Resetter
    6 Oct 2003
    Bit to late m8 ;) its done already, plus i dont want to cut the same stuff twice ;), and it looks pretty straight to me :rock:
  5. Geqxon
    Geqxon What's a Dremel?
    16 Jan 2004
    OMG, you used a wood/plastic saw to do aluminium?
    Realy, I hope you didnt breathed the dust, you migth die of it..... :waah:
  6. kplonk
    kplonk What's a Dremel?
    1 Mar 2002
    Yep looks good to me, how many blads did you use?
  7. The_Resetter
    6 Oct 2003
    I think about 5 of them, give or take one ;)
  8. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    I dont think 5 is too many blades at all... Looking at the fact that they're not supposed to be used for metal ;)
  9. The_Resetter
    6 Oct 2003
    Yeeey I removed the first few bits of aluminium
    Closeup.
    These larger areas I cut with the jigsaw, speeds up the process a little bit. :hehe:
    Filing everything straight.
    And the end result, although the photo is a bit vague.
    djengiz likes this.
  10. djengiz
    djengiz Pointless.
    16 Aug 2002
    Excellent! Boem boem boink boink hakuh en zaguh! <- Another Dutch song :)
  11. ReFredzRate
    2 Sep 2002
    zaguh en hakkuh, wat een geluid!! :wallbash:
    Anyway, doing a good job Resetter! Still going to cut out a bit more from the panel?
  12. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    like the rad idea!
  13. th3madc0w
    th3madc0w What's a Dremel?
    7 Oct 2003
  14. The_Resetter
    6 Oct 2003
    Yup, ill post an update in a few hours :)
  15. The_Resetter
    6 Oct 2003
    Update time !!
    Maybe some people questioned them selves what are those 3 holes in each corner for?, well so I could get in with a small figure saw
    Anyway, I started modding with the nice warm sun on my back \o/ I just luuuuuve spring ;)
    I finalized the rest of the top window.
    Fist using the jigsaw roughly going next to the line.
    The corners with the figure saw
    All done, now the filing starts :sigh: all that manual labour ;) but hey I can say I made the case with my own hands, blood, sweat (a lot), and tears (for the times I busted my knuckles on the workmate :p)
    But the end result is worth it :D :hehe:
    Closeup of the fan screw hole. ;)
    :dremel:
  16. Butch
    Butch What's a Dremel?
    2 Oct 2003
    Looking dammmm nice. Your doing an excellent job of those straight cuts mate. Keep up the hard work!
  17. bootupbuddha
    bootupbuddha grunge modder
    3 Feb 2004
    outstanding
    How do you say 'Outstanding' in Dutch?
    Okay, now get back to work.... ;)
  18. The_Resetter
    6 Oct 2003
    That would be "Uitmuntend"
    :D
  19. toand
    toand What's a Dremel?
    17 Feb 2004
    That looks so sweet :p Ain't aluminium a great material to work with :D Modding my precious Lian Li PC7 now and all the cuts are made by hand :dremel:
    bit off topic though.. :hehe:
    Love the case, keep up the good work! :rock: :rock:
  20. naelq
    naelq What's a Dremel?
    14 Oct 2003
    :clap: :clap: :clap:
    GIM'ME MORE! :D
